put layers on center of canvas
Hello. I want to put layers on center of canvas like this video.
As you can see, all layers are placed differently,circle A is on x 100 y 200, circle B is on x 200 y 250,circle C is on x 300 y 0, etc.
So I need to check positions of all layers If I use keyframer.Seems It's not a best solution.
What is the best way to do that in TVPaint?
Re: put layers on center of canvas
Hmmm, looks like we do not have such a feature to do it easily.
I move your topic in Feature request
OK. I will move them manually.
Yes, sorry :/
I am not sure but if you import a png sequence all the pngs are aligned to the center of the canvas. So maybe if you have all circles as separate pngs you can import them into the project.
It would work only if the circles were orignally a image sequence.
If they were drawn in TVPaint, it's then more complex.
This might do what you want:
Create a new action in a custom panel, then cut and paste this script into the embed George script command.
Param none
ScriptName = "CenterAllLayers"
tv_GetWidth
Width = result
CenterX = Width / 2
tv_GetHeight
Height = result
CenterY = Height / 2
tv_LayerCurrentID
OriginalLayer = result
tv_LayerGetImage
OriginalImage = result
Counter = 0
LayerID = ""
For Counter = 0 to 1000
tv_LayerGetID Counter
LayerID = result
// tv_warn "counter = " Counter " layerid = " LayerID
ExitFlag = CMP(LayerID,"none")
IF ExitFlag == 1
EXIT
ELSE
tv_LayerSet LayerID
tv_BrushCut 0 0 Width Height 1 0
tv_BrushRestore Reset 1 Optimize 1
tv_Dot CenterX CenterY 0
END
END
tv_LayerSet OriginalLayer
tv_LayerImage OriginalImage
Hmmm, I probably missed something because I can't use your script Svengali
I just tried it and it seems to work. What do you get when you try it?Elodie wrote:Hmmm, I probably missed something because I can't use your script Svengali
- CenterAllLayers.tvpx
- (78.5 KiB) Downloaded 1113 times
Sorry I'm just too blond sometimes, I did a wrong copy paste
I confirm the script is working
This is a really great one, thank you Sven' !
Svengali wrote:This might do what you want:
Param none ScriptName = "CenterAllLayers" tv_GetWidth Width = result CenterX = Width / 2 tv_GetHeight Height = result CenterY = Height / 2 tv_LayerCurrentID OriginalLayer = result tv_LayerGetImage OriginalImage = result Counter = 0 LayerID = "" For Counter = 0 to 1000 tv_LayerGetID Counter LayerID = result // tv_warn "counter = " Counter " layerid = " LayerID ExitFlag = CMP(LayerID,"none") IF ExitFlag == 1 EXIT ELSE tv_LayerSet LayerID tv_BrushCut 0 0 Width Height 1 0 tv_BrushRestore Reset 1 Optimize 1 tv_Dot CenterX CenterY 0 END END tv_LayerSet OriginalLayer tv_LayerImage OriginalImage
Sorry for my ridiculously late reply.
Your script works greatly. Thank you Svengali . I will use it.
