Glad it works .Jean / Folimage wrote:Thanks a lot, it's work!
It was because of my french
Export TVPaint - Import After Effects 1.0.4
Re: Export TVPaint - Import After Effects 1.0.3
Hi Jean,Jean / Folimage wrote:Thanks a lot, it's work!
Nice to see you in the forum, after we discussed about it.
I'm glad this script was useful for you.
See you during the Cartoon Movie tomorrow.
wow. this is amazing!
but, it wont be better if the script export in PSD?
what are the advantage of use this script instead of export "clip: layer structure"?
I could make it work with png. Not with psd. For several reasons.I dont have scipting access to the funcion export clip:layer structure for instancejuansolimar wrote: but, it wont be better if the script export in PSD?
You can import the exported png into after effect and keep the timing with the included after effects script. You cannot do this with clip :layer structure.juansolimar wrote:wow. this is amazing!
But it is a personal taste , choose what you find the best.
Kind regards Mads
Hi there, i would like to use/test this script but i dont know what to do with those files inside .zip file that i downloaded cause YT video is private.
Can someone tell me what to do with those files?
I will make video avaleble again latest monday8ball wrote:Hi there, i would like to use/test this script but i dont know what to do with those files inside .zip file that i downloaded cause YT video is private.
-mads
it will be right on time,
tnx m8
tnx m8
The Video Should be availeble again
-Mads
-Mads
- schwarzgrau
Every time I try to export my project with your script I got a folder for every of my four layers, in every folder is the layerinfo txt file but only in one of the four are images.
I attached the TVPaint file, maybe you could tell me what I'm doing wrong.
- Kreal_01_2.zip
- (2.2 MiB) Downloaded 486 times
The script only export whats between mark in and mark out. and there is only images on the lowest layerschwarzgrau wrote:Every time I try to export my project with your script I got a folder for every of my four layers, in every folder is the layerinfo txt file but only in one of the four are images.
- schwarzgrau
Oh that's something I should have noticed. Thank you Mads
Great work on this script! Halleluja!
A question: What could be the reason my layers are in the wrong order in AE? (They are all there, except their order seems random)
- Lukas Sketch Panel
- TVPaint Pro 11.7.3
- YouTube.com/@ClubBaboo
- YouTube.com/@FrameOrder
I cant remember if i fixed the import layers in rightorderLukas wrote:Great work on this script! Halleluja!
Can you post screenshot of layer orders in Tvp and layer order in Ae. And whar version is your Ae?
