Display bugs on Mac Standard version
Mabouh
Post by Mabouh »
Hello everyone,
We got some display bugs on TVPaint last standard version, on Mac 10.8.5 (work on Cintiq) :
- As you can see on the screenshot, the light table did not appear entirely. We closed and restarted the software and it came back. Don't really know what could be the cause of the bug :/
- While using the Transform tool, we could see only the green square but the handles on the corners + the rotation handle were not visible, and we could not use them.
Capture d’écran 2014-05-06 à 10.00.09.png (17.81 KiB) Viewed 16847 times
Re: Display bugs on Mac Standard version
Wow O_o
That's a weird bug, indeed !
Have someone else ever experienced this ?
neonnoodle
Post by neonnoodle »
Elodie wrote:Wow O_o
Yes, I have experienced this bug in TVP Pro 10.5.5 on the Asus Vivotab Note 8, running Windows 8.1 in landscape mode.
But was it "like" this immediately or did you have a normal panel and then, for no reason, it became like this ?
it's multi-OS. I had it once without being able to reproduce it.
2dbert
Post by 2dbert »
Has there ever been found a method to fix this? I am experiencing this bug right now, and any suggestions would be very much appreciated (see my set up in the signature)
Yiynova MSP19U
TvPaint Animation 11.0.6 Pro
I have had this happen occasionally :
"While using the Transform tool, we could see only the green square but the handles on the corners + the rotation handle were not visible, and we could not use them."
No clue about WHY it happens. (I can't reproduce the phenomenon at will) Usually if I resize the whole project window it fixes the problem (the handles reappear on the corners of the green box of the Transform Tool) . OR the other thing I do is I save the project and Quit TVPaint , then re-start TVPaint and re-open the project and the problem is fixed.
