Lukas
Posts: 534 Joined: 14 Jan 2011, 11:15
Post
by Lukas » 22 May 2014, 15:51
How do I run the scan cleaner on all heads of a layer?
I've tried making an FX bin called 'ScanCleaner' and use:
tv_StackLoadBin ScanCleaner
tv_StackApply heads CurrentLayerAllFrames
But it's not working. I'm stuck! Any help is appreciated!
LukasKrepel.nl
TVPaint Pro 11.7.5
MacBook Pro i7 2018 macOS Sonoma 14.6.1 + PC Windows 10
Wacom Cintiq 27QHDT + Wacom Intuos4
YouTube.com/@ClubBaboo
YouTube.com/@FrameOrder
Posts: 4102 Joined: 17 Feb 2006, 22:50
Post
by ZigOtto » 22 May 2014, 17:21
also, take care to :
- enable the FX before adding it in the stack bin,
- store the FX in the right bin, the one for the whole stack
(in the head menu-bar, (not those for individual FXs)
Lukas
Post
by Lukas » 23 May 2014, 10:34
Thanks guys, it works.
tv_LayerSelect ProjectStartFrame ProjectEndFrame
tv_StackApply
tv_layerRecomputeExposure
I couldn't get it to only apply it on heads, so I recompute exposures after applying.
http://wiki.tvpaint.fr/index.php?title=Tv_StackApply " onclick="window.open(this.href);return false; < This seems odd.
LukasKrepel.nl
TVPaint Pro 11.7.5
Post
by ZigOtto » 23 May 2014, 14:54
this command line works fine here,
no need to select the frames, nor to post-recompute.
Lukas
Post
by Lukas » 23 May 2014, 15:21
ZigOtto wrote: Code: Select all
I just tested it again.
Here it really just applies it on the current image in the current layer. (not even the head, it breaks the instance too)
Strange...
LukasKrepel.nl
TVPaint Pro 11.7.5
Post
by ZigOtto » 23 May 2014, 16:48
I was on PC (32bit session), and it worked as expected,
not yet tested on my 64bit partition.
