remote control frame by frame shifting problem!
Kayaha
Post by Kayaha »
I am working on Mac book pro with TVP animation 10 pro(10.5.5-64 bit)
to my surprise suddenly the remote control with is on current project window stop working correctly...I need to go from one fram to another just used to use the bottom with two triangle and plus , there and back...It worked correctly but suddenly it stopped.Now it jumps to the beginning of the animation , and to the end of animation. Why? what has happened?it strangely work still with keyboard! so I am saved... But feel uncomfortable that the program function is disturbed and it is not stabil!What will happen next?
Re: remote control frame by frame shifting problem!
Did you have an old version of TVP from a long time ago and now have a new one? This has been changed from frame to frame advance, to instance to instance advance, which is much better.
Please post your questions only in one place. I have answered your question in the other place.
Kayaha
Post by Kayaha »
hey ,
I have the same version since the beginning, it just stop working form one day to another.
sorry for posting twice...I haven't seen it
This is strange. Let me see if I understand: the symbol with the plus sign you are talking about is called Previous (and Next) Instance when you hover your mouse over it, isn't it? But you want it to jump from frame to frame even if your cursor would be sitting on an image layer (like it used to be). Do I understand correctly?
Kayaha
Post by Kayaha »
yes, exactly...I have solve already situation, I downloaded the newest version... and it works now everything...But anyway that was total disorder...
Kayaha wrote:I am working on Mac book pro with TVP animation 10 pro(10.5.5-64 bit)
You should update to the 10.5.7 version of TVPaint Animation first.
Guys, if a subject is created twice, do not answer both :wink:
