Interface Font
Ron Zorman
Interface Font
Post by Ron Zorman »
This is a crazy problem but one i feel i ran into once before and fixed but i'm not sure how.
I've managed to change the font style for the display interface and can't get it back to what it once was.
The 1st image is a screen cap of my old TVP 9 which I still have but the TVP 10 use to look like this as well
so this wasn't caused by an upgrade. (sorry if this is confusing)
I have uploaded 2 attachments of screen caps
What it use to look like
TVPaint 9.jpg (138.93 KiB) Viewed 10607 times
What it now looks like
TVPaint 10.jpg (108.97 KiB) Viewed 10607 times
I'm running Windows XP
TVP Animation 10 Pro 10.5.7 -32bits
Thanks for whatever help you can give.
-ron
ps. love the software by the way
schwarzgrau
Re: Interface Font
Post by schwarzgrau »
Maybe it would help to know how you changed your font.
Re: Interface Font
what I would do :
1)try to set back the Interface color sheme to "default" (if it's currently on "custom" or another preset),
2)try to start with a New Config, and see what happen (regarding the interface font),
3) if none of 1) or 2) is working, the ultimate weapon consist to edit the tvpaint.loc file*
in WordPad or any other text editor (*... usually not recommended to tweak it),
you will find it in C:\Program Files\TVPaint Developpement\TVPaint Animation 10 Pro (32bits)\Data\...,
there, you can change the font name and the font size to whatever else (among your available vector fonts correctly installed),
but take care and make a backup of the initial tvpaint.loc file first,
so if something is going wrong, you will be able to easily "undo" your own customisation.
8)
Ron Zorman
Re: Interface Font
schwarzgrau wrote:Maybe it would help to know how you changed your font.
Sorry I was unclear.
I didn't change any font on my system or in TVPaint. I just opened it and it was different I must have done something
with a hotkey by accident or something, the problem was I don't recall doing anything.
Ron Zorman
Re: Interface Font
ZiggOtto,
Thanks, I went right to option 3. and found the problem when I compared TVPaint 10 versions .loc file to the TVPaint 9 version.
Still not sure how or why but as long as it's fixed I'm much happier. Thanks soooo much.
-ron
Re: Interface Font
Ron Zorman wrote:... as long as it's fixed I'm much happier.
8)
