tvp 32 bit versions no longer work
CharlieC
Post by CharlieC »
hiya-
any ideas why the last few versions of tvp 32 bit won't open, but freeze up at blank white 'dialogue' box? and then i need to force quit. (no computer or other tech changes on my end that i know of...)
i usually use the 64 bit versions, but i often rely on quicktime exports to use in after effects since QT is not supported in the tvp 64 version. (the tvp AVI work well, but the file icons don't show as images without some extra software that i need to get...)
Charlie C
charliecanfield.com
Mac mini (M1, 2020)
chip Apple M1
memory 16 GB
(currently running Monterey 12.6)
Cintiq 22HD (2015), driver 6.3.36-2
Re: tvp 32 bit versions no longer work
Hello Charlie,
Are you running TVPaint Animation on Windows or MacOS ?
Also, have you tried to create a new configuration ? (Preferences > Startup > Open Startup Panel and then create a new configuration when TVPaint launches)
CharlieC
Post by CharlieC »
cool-
i tried that and it does work, altho' i'm not sure why. is it something embedded in my usual default configuration?
will the problem copy over my usual configuration with all it's keyboard shortcuts, room setups, and tool bars?
btw- my system details should be in my signature; mac 10.6.8 etc.
thanks,
Charlie C
charliecanfield.com
Mac mini (M1, 2020)
chip Apple M1
memory 16 GB
CharlieC
Post by CharlieC »
interesting-
now when i open tvp 32 bit it does fully open correctly even if i still use the old default config, and not the new config. so creating a new config initiated a general fix or reset or something?
Charlie C
charliecanfield.com
Mac mini (M1, 2020)
chip Apple M1
memory 16 GB
it would be difficult to explain deeply how it works, but yes.
