GEORGE include file
Mads Juul
GEORGE include file
Post by Mads Juul »
Here is an include file with the george commands listed here http://wiki.tvpaint.fr/index.php?title= ... _Reference
---EXAMPLE---
A project is called “007_atThePark_v006_L.tvpp” and you want to increment and save the project as “007_atThePark_v007_L.tvp”
1) Download this attached file "Include.grg" and save it in the George folder of TVpaint
2) make a textfile called "incrementalsave.grg" in the same folder
3) in "incrementalsave.grg" paste the following code
project_incrementalSave("_",3,1,3)
#INCLUDE "Include.grg"
4) In tvpaint make a new custom action in a custom panel.
5) in this custom button choose Edit>set Script
6) Browse and select "incrementalsave.grg"
7) Press ok and save changes to Custom Action
8 ) now you have a incremental save function
EXPLANATION OF project_incrementalSave TO MAKE IT WORK WITH OTHER FILE NAMES
the function "project_incrementalSave" is called with 4 variables
project_incrementalSave(divider,part,ask,minimumDigitLength)
let's say we want to increment a file like this
 test1_01.tvpp
I go through each variable
divider
Which divider in the file name should be used to look for the part to increment. I usually use "_" but it also could be "-" or "#"
So lin the example "test1_01.tvpp" the divider would be "_"
part
Which part of the string split by the divider should be incremented. . The base name in the example is "test1_01" so it is the second part. so the second variable should be 2.
ask
The variable could be 0 or 1. If 1 a popup appears where you have to confirm you want to save an increment. if 0 the scipt saves an increment without asking.
minimumDigitLength
so how many digits should the increment be? the example file is " test1_01.tvpp" . The part incremented is "01" so it is 2 digits . so the 4'th variable should be 2.
(Thinking about it it should be possible to get rid of this 4'th variable. but anyways as the function is now . it needs it)
this gives this code to make it work with your file
project_incrementalSave("_",2,1,2)
-Mads
Include.grg
(21.5 KiB) Downloaded 266 times
NathanOtano
Re: GEORGE include file
Post by NathanOtano »
Thank you! Reaaaaally nice to have it ready to use. I already included your homemade procedures in my scripts but i just wanted to say thank you for all of this :) if you update something just tell me.
Mads Juul
Post by Mads Juul »
NathanOtano wrote: if you update something just tell me.
I will. I made 2 changes today so I will post them in a reply in this thread something like
//****CHANGELOG 2014-11-11
string_addZeros(prefix,string,length)
Second parameter can be a string instead of an integer with letters before and after string
string_addZeros("/","m1j",5) will return "/m00001j"
project name can start with a number like "0001_v01.tvpp" without the leading zeros disappear when saving
schwarzgrau
Post by schwarzgrau »
My file is called, test1_01.tvpp and if I use the button it gets saved under the same name. Is there any naming convention I should follow?
By the way if I try 007_atThePark_v006_L.tvpp it gets saved as 007_atThePark_v007_L.tvpp
Mads Juul
Post by Mads Juul »
schwarzgrau wrote: Is there any naming convention I should follow?
Yes the function project_incrementalSave is called with 4 variables
so let's say we want to increment a file like yours
  test1_01.tvpp
divider
So let's say we have your file name test1_01.tvpp the divider would be "_"
part
ask
minimumDigitLength
Hope this helps.
Kind Regards Mads
schwarzgrau
Great you can customize it that way. Thank you Mads
Mads Juul
Post by Mads Juul »
you're welcome
schwarzgrau
I got the filename Ausstieg_04_01.tvpp and my george-script looks like this
project_incrementalSave("_",3,1,2)
If I use my increment and save button the new file-name is Ausstieg_4_02.tvpp what is completely correct, but the leading zero in front of the four gets cut away. Is there a way I can keep this zero?
Mads Juul
Post by Mads Juul »
schwarzgrau wrote:I got the filename Ausstieg_04_01.tvpp and my george-script looks like this
unfortuanately it It looks like a bug in the script. So you would have to put a character infront to keep the zero
Austeig_s04_02.tvpp
-Mads
schwarzgrau
oh that's fine with me, I can add a V for version. Thank you Mads.
