Tvpaint Support Xeon Phi? And Real-Time FX Preview/Flipbook?
TheQuestionMark
Post by TheQuestionMark »
I just check some tech new that there is a new Intel's Xeon Phi. I was wondering does TVPaint Supports Xeon Phi? Exporting Video, Motion Keyframming, and FX effects is really time consuming. If I were to get a Xeon Phi would would the rendering and my work workload really speed up? I saw a deal for $200 bucks out of $2K!, I'm really panicking to buy one! So is it a good to buy a Xeon Phi for TVPaint alone to speed up working speed? It be nice to work at 5K resolution video with the Xeon Phi with all the mountains FX effects at high speed! Not only that Full Preview at 5K Resolution at 'Play Preview' without any hiccups or being choppy! Good Idea ,Bad Idea to get a Xeon Phi for TvPaint?
Oh if Xeon Phi is supported. Can the FX Panel Effects be set in Real-Time?
The FX Preview - Can the flipbook flip the FX effects too - 'Real-Time' FlipBook/ 'Real-Time' FX Flipbook? The 'preview' option in the FX panel doesn't seems like it's enough, can there be more option to the preview, Flipbook option/Flipbook FX Option? Is there a way to draw/edit and with real-time FX, you only want to edit your 'real keyframe' and not really edit the 'Apply FX for all Instances Keyframes' There are times seems like most of the time, I really I want the FX but I don't want with FX by 'apply FX' , I really want to only draw at the keyframe and using with 'Key Frame - Motion' and have the FX do all the work, Draw with FX without 'Apply the FX' you know?? "Drawing 3 Frames per 24 FPS, but the FX makes it have 24FPS effect" kind of like the Diablo 3/GuildWar2 Cutscene Effect sort of?
|||| This seems pretty hard to explain and confusing sorry. ||| When using Motion Keyframer+Blur I really don't want to set in the FX by 'Apply FX' only having to undo it, when using with Camera Panning, it's pretty time consuming the rendering 'apply the FX'. I also don't want, on the Motion-Keyframer+Blur FX that you have to 'Apply FX' and that you'll lose all the FX panel work part and your 'original keyframe' and also lose track on the 'real keyframe/real key original frame', is there a way to keep all of your the FX-"layered FX-wise" and keep your 'original key frame'?, also be able to still export video with FX without 'apply fx' but has the FX?
Drawing 3@60FPS with FX on Youtube! XD
Re: Tvpaint Support Xeon Phi? And Real-Time FX Preview/Flipb
Topic moved in the good sub-forum.
Features and improvement requests can be used only to notify real bugs or missing features, not to ask how does TVPain work and if it can be compatible with this or that device.
Thank you.
