magic ereaser blue 50% Topic is solved
juansolimar
Post by juansolimar »
Hi, i dont know much about script. i can create some toolbars and action, but nothing to fancy.
i want to create a button that erase only the blue in 50% in the entire image (because the blue by default its too hard).
anyone can give me some help?
thanks!
Mads Juul
Re: magic ereaser blue 50%
Post by Mads Juul »
This code turns down the aalpha channel in the blue channel of the current image with 50%
tv_pixelmatrix 1 0 0 0 0   0 1 0 0 0   0 0 1 0 0   0 0 -0.5 1 0
is this what you was looking for?
You can read about the command here
http://wiki.tvpaint.fr/index.php?title=Tv_PixelMatrix
I have also put it in a custom panel.
Hope it helps.
-Mads
MEB50.tvpx
(4.5 KiB) Downloaded 212 times
juansolimar
JUST PERFECT! THANKS MADS!!!!
(y suppose that if i change the "0 0 -1.5 1 0" for "0 -1.5 0 1 0" work with the red or green, right?)
Mads Juul
Post by Mads Juul »
juansolimar wrote:JUST PERFECT! THANKS MADS!!!!
Glad I can help.
Yes this should turn down the red channel
tv_pixelmatrix 1 0 0 0 0   0 1 0 0 0   0 0 1 0 0   -0.5 0 0 1 0
And this the Green channel
tv_pixelmatrix 1 0 0 0 0   0 1 0 0 0   0 0 1 0 0   0 -0.5 0 1 0
Zetariver
Post by Zetariver »
I didn't know geroge can control alpha value of Blue channel.
By the way, is it possible to fill only transparent areas(alpha value 0) with specific colors?
juansolimar
HI! i was wondering. what if i want to erease by 50% only the black lines?
thnks :)
meslin
Post by meslin »
Check out the half-erase panel I just posted in the Contents Sharing section:
http://forum.tvpaint.com/viewtopic.php?f=11&t=10684
David
