Copy and paste without resizing?
David_Fine
Post by David_Fine »
I have a project which is larger than HD. Say it's 2880 x 1602. I open a normal 1920 HD project and I want to copy an element from the larger project to the normal HD one. When I do that, either by copying and pasting the character or copying and pasting the whole layer, TVPaint resizes the to fit the lower rez 1920 HD, effectively reducing the quality of the layer. I don't want that! If I then enlarge the item it becomes fuzzy, of course.
I want an element which is 300 pixels wide to stay 300 pixels wide. In the lower rez project. Here is a picture which describes it really clearly. Can this be done?
David Fine
Snowden Fine Animation Inc.
Vancouver, Canada
Re: Copy and paste without resizing?
Custombrush does the trick.
Sewie
Post by Sewie »
And if you don't want any degradation, FX Panel > Add FX > Motion > Keyframer.
Looks pretty intimidating at first but follow the manual to see how it works because I think you will be using this a lot.
David_Fine
I am using the FX panel for camera moves, so I understand it, but I am unclear how I could use it to copy and paste from one scene to another, as described. Can you give me some idea as to what you mean, or where this is explained in the manual, because I don't see it there.
Custom brush is a great tip for grabbing one image. Thanks for that. If I want to take a whole layer, it would be a tedious process of doing it for every single instance.
David Fine
Vancouver, Canada
Sewie wrote:If you don't want any degradation, FX Panel > Add FX > Motion > Keyframer.
David_Fine wrote:I am using the FX panel for camera moves, so I understand it, but I am unclear how I could use it to copy and paste from one scene to another, as described. Can you give me some idea as to what you mean, or where this is explained in the manual, because I don't see it there.
Here is how I would do what I think you are trying to do:
In the FX Stack > Motion> Keyframer , go to the Render tab . From the Source drop-down menu select your first project (the overscale 2880 x 1602 project) as the Source. Now go back to the Position tab in the Keyframer and use the X-Y-Z coordinates to adjust the size and position of the images to what you want. Now , apply FX Stack. (to retain the exposures on your frames from the first project be sure to apply the FX from the "FX" button in the Animator Panel instead of the "Apply FX Stack" button at bottom of the FX Stack panel) .
Spoiler : :
Here's your original over-scaled 2880 x 1602 project:
In the second project (1920 x 1080) , go to FX Stack > Motion > KeyFramer > to the Render tab and select your first project (the over-scaled one) as the SOURCE :
Now make any position or size adjustments using the X-Y-Z coordinates in the FX Stack panel and then select all frames and Apply FX from the FX button in the Animator Panel:
And here are the results :
I did this by using the Project modifier:
1. Modify Large project to make it emulate the exact size of the small project, but first check "Correct Aspect Ratio". Check stretch to new size and press modify. This will result in shrinking the project window around the images but the images will not shrink.
2. copy gorilla layer from the resulting modification and paste into waiting smaller project. Done.
EDIT: The expression "Correct Aspect Ratio" has never stopped confusing me because it can either mean that my current AR is correct, or that I need my current AR corrected as well. I suggest it to say "Don't change current image size" because Aspect Ratio sometimes refers to the image and at other times to the project window's size and in this case we are dealing with both. It's very confusing.
David_Fine wrote: Custom brush is a great tip for grabbing one image. Thanks for that. If I want to take a whole layer, it would be a tedious process of doing it for every single instance.
no, the custombrush can pick up animations!
- select the desired range of frames.
- pick up the brush.
tvpaint will ask you: "Cut out an animbrush?"
- answer "yes"
It's a good point to remind the user at this point that more than just one image can be picked up with the cut brush. But I will argue that there are more clicks involved with the cut animbrush method than with simply creating a modified project and grabbing the entire layer out of the modified project and pasting it into the smaller project, instead of having to deal with the trouble of accurately stamping down the picked up images into the smaller project.
David_Fine wrote:I have a project which is larger than HD. Say it's 2880 x 1602. I open a normal 1920 HD project and I want to copy an element from the larger project to the normal HD one. When I do that, either by copying and pasting the character or copying and pasting the whole layer, TVPaint resizes the to fit the lower rez 1920 HD, effectively reducing the quality of the layer. I don't want that! If I then enlarge the item it becomes fuzzy, of course.
The other way to do this is to set the Camera Tool parameters within your 2880 x 1602 project to 1920 x 1080, then when you Export to a .mov change the Export setting to Camera View .
Spoiler : :
Here is the original 2880 x 1602 project :
Set the Camera Tool parameters to 1920 x 1080 :
In the Export window set the View to CAMERA :
Which accomplishes the same thing as copying & pasting the 2880 x 1602 project to a new 1920 x 1080 project .
But I don't see how David is going to get out of a MOV file a timeline -- or anything else uncompressed.
David_Fine
I continue to be amazed and delighted by how helpful this community is. DT Nethery, thank you so much for your detailed illustrations. So helpful. And everyone else for the comments and suggestions too. For me, the two best ways to proceed is using a the custom brush when I only want one image, or using the FX stack when I need the whole layer. As Paul points out, using the custom brush to pick up multiple instances and then paste them onto the new project is a lot of clicking and time. The brush is super quick and easy when I need just one and the FX stack gives me the control and timing.
Having said that, I think it would be a whole lot more straightforward if TVPaint simply copied and pasted a layer without resizing, or at least with an option, like using the ALT key to choose one way or the other. Resizing to fit the incoming project is an extra step TVPaint assumes I want. I might, but I might not. If I could simply copy a layer, and then paste into another project with an option to match or resize, that would be so quick and easy. If the image was bigger (bleeding outside the frame) it should keep the image so that you could move it around and then lock down the position. I imagine this is a very simple adjustment to TVPaint to allow this because the present default is actually doing more than I want, not less.
Again, thank you all so much. :D
David Fine
Vancouver, Canada
