TVPaint Animation 11 : ask all your questions here !
Sewie
Re: TVPaint Animation 11 : ask all your questions here !
Post by Sewie »
ZigOtto wrote: but I'm adding my vote for a specific Guideline/Undo to navigate in the historic changes applied on the guideline by the user.
(so, imo, not a bug, ... but a feature request).
Yes, that would work for me as well.
Sewie
Post by Sewie »
Elodie wrote:On TVPaint 10.5 : yes, no problem (except if you are using features from 11 : they will disappear on TVPaint 10.5).
On older versions, files won't be compatible (you must uncheck tvpp compression in your preferences).
And when upgrading from TVP 10.5, will it keep my old preferences? Like keyboard shortcuts and custombuttons, -brushes and -panels? I have for instance an Animator Panel that I have added custombuttons to. Will they migrate or should I save them and then re-import them in TVP11?
It will be better to re-import everything.
neonnoodle
Post by neonnoodle »
Is there a keyboard or mouse shortcut for locking points in place in the new Warp tool? Or is the only option to right-click->lock each individual one?
schwarzgrau
Post by schwarzgrau »
Sewie wrote:WOW!
That new Warp Tool is blowing my mind!
I feel the need to second this!
Sewie wrote: It looks like you've focused on the software's strength (hand drawn 2D animation) and added to it. (Perspective tool, the new warp tool, which will open up many new possibilities animation-wise, I believe). And I'm very glad you've left the silly embellishments - half-assed storyboard camera's and ftp functionalities, for example - for what they are.
And this!
The new CTG-layers are working suprisingly good too.
neonnoodle wrote:Is there a keyboard or mouse shortcut for locking points in place in the new Warp tool? Or is the only option to right-click->lock each individual one?
You can select some points through one action by holding the [Shift] key and moving your stylus/mouse.
Lukas
Post by Lukas »
Fabrice wrote:
Is there a quick way to move the line animation together with the color layer without using the FX stack?
here is a hint : the same instance within a CTG layer can be used on several source images.
Not really what I meant, see attached screencapture. Hopefully it illustrates the problem.
First I move the line animation. Then I hit return to re-apply the move on the CTG layer, but I get a black line instead. When I reselect the move tool to manually move the CTG layer, it's unavailable.
(Ideally, I'd put both layers in a folder and move the folder.)
Screencapture.mov
(7.74 MiB) Downloaded 1251 times
  • Lukas Sketch Panel
  • TVPaint Pro 11.7.3
  • YouTube.com/@ClubBaboo
  • YouTube.com/@FrameOrder
Sewie wrote: And when upgrading from TVP 10.5, will it keep my old preferences? Like keyboard shortcuts and custombuttons, -brushes and -panels? I have for instance an Animator Panel that I have added custombuttons to. Will they migrate or should I save them and then re-import them in TVP11?
About plugins: I highly recommend that you first save each plugin separately as a tvpx before upgrading. This means if you have a collection of plugins under one custom panel, you should still make a backup save for each plugin. Once you upgrade and import these, DO THE SAME THING OVER AGAIN. Save each plugin as an individual tvpx from TVP 11. Then you will have no trouble. If you don't do this, it might happen that you will one day soon find that certain plugins just quit working.
The same goes for custom ini. and other files such as key configs. Before upgrading, make double sure each one has been saved. Once you import them into 11, they will all function as expected.
Sewie
Post by Sewie »
But you mean custompanels/brushes, don't you Paul?
I don't have any plugins in TVP 10.5, but I do have loads of custombuttons, -brushes and -panels.
But it's good to know that I should re-import them. Then exporting tvpx's from TV11, as you mention, is meant as a precautionary backup?
Sewie wrote:But you mean custompanels/brushes, don't you Paul?
Correct. Custom brushes have no problems. I just wanted to make sure that anyone reading this knows to treat plugins gingerly since sometimes these get referred to as buttons too.
EDIT: Plugins must be exported again from v11 to become associated with 11 -- otherwise they can stop working. It is not just a double safe measure.
schwarzgrau wrote:I don't like the butterfly icon very much, but the new interface looks great.
Sewie wrote: Me neither, frankly, it makes the software look like a make-up box. The TVP logo would look more professional, I think.
Robobob wrote: I agree the butterfly is a bit dommage but that doesn't really change the program.
+1
habashtvpaint
Post by habashtvpaint »
Wow what an amazing upgrade
my winner features are:
- CTG layer (extreme timesaver)
- the new GUI (Professional look and feel)
- 2K and 4K screens (Professional under the hood)
- Layer Preset Manager (extremely handy)
- Warp Tool (last minute exaggeration)
- Chromatic Wheel (colour theory expert are all happy)
Thank you TVP team, long live tvp development
Cheers,
A
Animator for Life
Mac | 3.5GHz i7 | 24GB RAM | OSX 10.9 | TVP 11 Pro 64bit
Have you checked out my favorite, the Library?
Lukas
Post by Lukas »
Fabrice wrote:
I understand what you're suggesting and it's a nice feature, but it has little to do with the issue I posted and doesn't solve the problem I described with the screencapture at all.
Locked
