- Panning Tool.jpg (30.85 KiB) Viewed 15602 times
Panning Tool in keyboard shortcuts?
For some reason I cant find the 'Panning Tool' in the keyboard shortcuts? Has it been removed or renamed because I vaguely remember having set it in the past?
Re: Panning Tool in keyboard shortcuts?
tools: Position Reset Scale ?
Just tried it but that's not it...
Very strange because 'Reset Panning' is available in the Keyboard Shotcut window.
What are you looking for it to do? Is it that you want a keyboard shortcut to select the panning tool and once you press that key you can move your drawing around? If that is it, it works for me.
Exactly that.Paul Fierlinger wrote:...Is it that you want a keyboard shortcut to select the panning tool and once you press that key you can move your drawing around?
But when I set 'Position Reset Scale' it resets the scale for the Transform Tool, which makes sense.
I want to set the Panning Tool because (I recently found out) it can move drawings without degrading them.
I spotted my mistake. When I tried the key command I was still under the influence of my custom button. Here it is:
Thanks Paul! I'll set the button.
But the omission of this option in the Keyboard Shortcut is a mistake, I believe, so: Bug Report!
- schwarzgrau
It's under SHAPE TRANSFOM >> PAN
Ah, for crying out loud! Thats it. Got lost in translation again, I suppose.
Thanks, Schwarzgrau.
Edit; But I think it would be good if it got renamed as 'Panning Tool' in the Keyboard Shortcut window, just for clarity sake.
So forget the Bug Report and now it's a; Feature Request.
- schwarzgrau
Yea, it would make sense if the tool-tips match with the shortcut functions.
Ah, so that's what happened. I saw that Shape Transform Pan command from the beginning and thought the Key Command Panel was referring to my plugin, so I copied the button, shortened the name, and sent it here. This has also fooled me before. Often you can't tell if the panel is reading your custom panel or referring to the real, built in thing.
Localization error tracked. Thank you !
