Change line colour
schwarzgrau
Re: Change line colour
Post by schwarzgrau »
I was annoyed that I always needed to recompute the layers instances, so I added the command. Maybe somebody else will find it useful.
All credits still go to Svengali and Mads.
Acolor.tvpx
Fill your layer with A color.
(57.5 KiB) Downloaded 1913 times
Hey Marc, have you noticed you can now disable auto break on the layer of your choice ? Then, you don't need to recompute anything.
schwarzgrau
Oh of course! Thank you for reminding me
cgmodeler
Post by cgmodeler »
Just found this script while trying to get a custom AColor to work on a pixelmatrix but noticed that the pixelmatrix modifies the alpha and gives an awful white premult.
So in short, can anyone point me into the right direction on how to modify the script to work only on heads?? The script is no longer working if you don't have a selected frame, and this will avoid having to recompute or enable/disable the auto-break instance.
I tried using the tv_cmd Heads before the tv_rectFill:
tv_SetDrawMode "color"								// assure that color mode is selected
tv_cmd Heads tv_RectFill 0 0 PWidth PHeight 0				// fill frame with APen color (excluding alpha area)
END
At the process part but got no luck.
Can anybody help me out here?
Thanks :D
www.cocoalopez.com
NathanOtano
Post by NathanOtano »
When running your script use "tv_exposureinfo" http://wiki.tvpaint.com/index.php?title=Tv_Exposureinfo
And use the "IF..." operator to execute your action only if result is a head
To preserve alpha you need to activate alpha on the layer with a command, and deactivate it at the end of your script if you want alpha off afterward. With http://wiki.tvpaint.com/index.php?title=Tv_Preserve
But I see that your script doesn't run "on selection" kind of. If you want a proper script, you should detext selection, then iterate with the "while" or "for" operator on the images inside the selection :) look at the "layer run" code at the end of this page for exemple : http://wiki.tvpaint.com/index.php?title ... s_:_Layers
Scripts are not that hard, but there is no magical trick to go faster than writing every action :) maybe have a look at svengali's script to see how it looks like
But right now if you desactivate auto-exposure creation and activate alpha on your layer, it should work maybe?
cgmodeler
Post by cgmodeler »
Thanks a lot Nathan for pointing the way.
I fixed and added a few things to Svengali script to work properly with V11
For some reason the detection of non selected frames wasn't working on V11, perhaps it needed some extra "d d d " after parsing the result of the "tv_LayerInfo" but i'm not sure.
I'm attaching the modified version if anyone needs it.
It will remove the autobreak instances to avoid creating extra frames
If clicked will colorize only the current frame
When selecting several frames it will colorize only selected frames (without breaking instances)
MatteLayer.tvpx
(58 KiB) Downloaded 1807 times
www.cocoalopez.com
NathanOtano
Awesome :) well done!
schwarzgrau
This is still something I would love to see as a build in feature:
Select one or several frames, press a button and get the content filled with your A/foreground color.
cgmodeler
Post by cgmodeler »
schwarzgrau wrote: 24 Oct 2021, 15:43 This is still something I would love to see as a build in feature:
You can map the script to a hotkey I used CTRL + Backspace (Almost like photoshop)
www.cocoalopez.com
schwarzgrau
Thank you. I already got that set up, but It would be great if this could be a regular feature.
kelanhordos
Post by kelanhordos »
Hello, this useful script was broken with v12, I've updated it to work. The change in v12 was to tv_preserve, it requires that "Alpha" no longer be written before the On/Off etc. parameter. Simple fix for any other scripts that might use the same command.
MatteLayer.tvpx
(58 KiB) Downloaded 1228 times
Tvpaint 12.0.1 Pro
