Hello every one
I'm struggling to download some of the brushes that are shared as a zip file. the ones that are .tvpx work perfectly but the zip ones when I try to unzip it give me another zip file (.bin) and when I try to unzip that it gives me another zip file (.cpgz) and then if I unzip that it will give .bin again and it gets stuck in a continuous never ending loop of unzipping between .bin and .cpgz. Any ideas what I'm doing wrong?
I have a tvp 10 pro
Macbook pro 2009
OS X Yosemite 10.10.2
I appreciate any help
Unzip problem, custom brush panels from the content sharing.
Re: Unzip problem, custom brush panels from the content shar
when the fisrt time you got a xxx.bin file (+ a folder named xxx.data), it's all you need ...
(it was the original Custom Panel format before the .tvpx format came).
in tvpa, you'll just have to open it via the menu Windows /Custom Panels /Open a New Tool Bar,
or via the Custom Panel icon of the main bar : ... Open a New Tool Bar,
then, browse and select your xxx.bin file, hit "OK", ... that's it.
(it should be added in your custom panels list)
