TVP 11 - Color Mixer - not able to pick color ???
Animark
Post by Animark »
again I tried to get warm with the 11. I worked with the color mixer panel.
Normally it has two options:
- unlocked Mode: you can smear the mixer
- locked mode: you can pick the color (without having to select the pipette or color picker)
The last mode is not working in TVP 11. Would be nice if someone could confirm. Mabe it's my fault ...
TVPaint 10.5.7 - Win10/64
TVPaint 11.0.8 - Win10/64
CLO
Re: TVP 11 - Color Mixer - not able to pick color ???
Post by CLO »
Hi Animark,
We made a few changes in the Color Mixer panel.
With the unlocked mode, you can smear the mixer, right. And with the locked mode, you can not mix the colors.
In both modes, to pick a color, you have to select the pipette (A or B) or use the shortcut [;], or the sub-menu > Pick Color
Animark
Post by Animark »
Oh, that's too bad. I use it very often. Thanks for your answer.
Thank you for this report Markus : other "old" users gave us this feedback, so we will keep this in mind for future updates ;)
