I'm using TVP v 11 pro 64 bit on Windows 7 64 bit.
Often when I'm using the transform tool the selection area fails to appear, and instead I get a little red square in the top left corner of the drawing area, which seems to serve no function. I have to restart the program to get the selection tools to work again. What's happening?
Thanks
Dennis
Transform glitch
Re: Transform glitch
This happens to me when I'm accidentially in an empty layer instead of the frame which I want to transform. Always check your active layer first!
ah - I thought it must be something stupidly simple. I'll watch for that next time it happens. Thanks!
Also see if stencil is enabled on a different layer. You cannot use the transform tool when stencil is enabled, unless you use the selection tool first.
