Mac OS X 10.10 Yosemite and TVPaint Animation
Locked
Re: Mac OS X 10.10 Yosemite and TVPaint Animation
In your situation, the first step would be to try in TVPaint 11 demo if the issue is still there.
skomdra
Post by skomdra »
I did. The problem with lagging while zooming, scrolling and turning table is still there, I am still not sure about drawing, I have to spend little longer with that.
TV Paint 11.5.3 Windows 10
schwarzgrau
Post by schwarzgrau »
There are no updates for 10 to fix a problem with Yosemite, which came out long before 11? If 11 was out three month before Yosemite I would say it's the way things goes, but this is really bad support.
skomdra
Post by skomdra »
schwarzgrau wrote:There are no updates for 10 to fix a problem with Yosemite, which came out long before 11? If 11 was out three month before Yosemite I would say it's the way things goes, but this is really bad support.
I agree. Imagine all those kids just out of school with no. 10 licence and getting a new Mac for Christmas. Starting tvPaint, and darn! Father, can you give me some more money, my program doesn't work any more? Father: nope. You already have your Christmas present. How many cases like that is possible at the end of 2014?*
*It's irony, if somebody didn't get, bot yes, schwarzgrau, no way I can accept this as a good support. Maybe I am in minority, but nether the less, problem still exists and it can't be a user responsibility to solve it.
p.s. and to any possible idea (which I heard) that in this case the user should go step back in the OS, instead of using the new OS, just a reminder of the Apple policy: They are not supporting downgrading the OS from the OS which is on the machine at the moment of purchase, in this case it was Yosemite. So, it is not possible to do it, legally speaking.
TVPaint's code was splitted in July, 3 or 4 months before Yosemite came out. By the time we had access to preview versions of Yosemite (in September), there was no issue at all (it was even more stable on Yosemite than Mavericks).
There was the old TVPaint 10 branch, and the TVPaint 11 one, in which so much modifications were made (interface, CTG layers, Library...) that it would have been impossible to go back in the old TVPaint 10 branch.
Also, in our initial plans, TVPaint Animation 11 was supposed to be released in October/November, but we prefered to delay it to February to have a more stable version, and more features (for example, the Anti-Aliasing for the Paint bucket was made in that time).
There will no longer be any updates to TVPaint Animation 10 : the last version is 10.5.7. We still answer questions and let users download the last version, but we no longer work on the old TVPaint 10 code.
skomdra
Post by skomdra »
Thierry, I understand and sympathise with your point, but this is not a solution to my technical problem. So did I get this clear, in other words what you are saying is: there is no solution to this problem, or, you can use this version software only on older mac machines or you are forced to buy a new version of software. Is it?
A little thing. Have you checked this ?
skomdra
Post by skomdra »
yes, no lagging in tvp when I start in lo res on 11! :) so that was it. But on 10.5 is still lagging. It is comforting thou that at least the new version will not lag. Thanks Elodie.
Lukas
Post by Lukas »
I fully agree...
  • LukasKrepel.nl
  • TVPaint Pro 11.7.5
  • YouTube.com/@ClubBaboo
  • YouTube.com/@FrameOrder
Elodie wrote: A little thing. Have you checked this ?
skomdra wrote:yes, no lagging in tvp when I start in lo res on 11! :) So that was it.
A question: how would someone who does not frequent this forum know to do this ? (start TVP 11 in low-res. on Yosemite ) . It is not mentioned in the FAQs or in the User Manual.
Open TVP 11 in low-def.jpg (56.91 KiB) Viewed 36278 times
Hmm, you're right, it should be mentionned at least in the FAQ, we'll add it.
It was not in FaQ because this problem concerns only Mac with retina screens (and until now, very few people gort such expensive computers), so the problem was not fréquent (i've maybe answered this problem 3 times since the release of the first retina mac book pro).
burnsta
Post by burnsta »
Chillrobski wrote:I've been experimenting with why my lines were jagged and choppy with the Yosemite upgrade. I learned that if I expanded to full screen on my Mac the lines became smooth again. ( Press the green button on top corner of the program. ) I've attached some examples and hope this helps. THX
:roll:
A full day of searching thru Adobe, Wacom and Apple forums...
So simple and it works.
You are a genius!!!
Thanks! :D
Soom
Post by Soom »
Not sure if to post it here, or in a separate topic.
I am trying out TVP 11 on Yosemite now. And ... frankly - I'm completely baffled and quite upset:
1. The line lag issue, that was discussed here already - OK, it works fine, when TVPaint is in Full Screen mode. But, does it mean, that in Window mode it will not be functional? What about the Standard version - does it have the Full Screen mode in TVP 11? Because in 10 it doesn't...
Also - I don't see "Open in Low Resolution" in the properties. what I see instead is "Open in 32-bit mode". when I try it - nothing changes...
2. The upper menu disappears behind a gray bar - clicking on it reveals the menu, but after switching apps it disappears again. looks like a bug (check the screen-shot)
3. And now to the worst of it - I tried also 32-bit version, and well - it crashes on start. It just doesn't start. Does it mean that there is no working Standard version of TVP 11 for Yosemite?
Just for clarity - TVP 10 standard works perfect.
Screen Shot 2015-07-03 at 11.31.43 (2).png (226.7 KiB) Viewed 35921 times
https://vimeo.com/danas
Soom wrote:Not sure if to post it here, or in a separate topic.
The "Open in Low Resolution" only appears with Retina displays. Do you have one ?
That is a known bug, and we're working on it. However this probably won't be fixed for next build.
Just because it doesn't work for you doesn't mean that everyone has the same problem.
It may be because of your config. Did you copy-pasted your config from v10 to v11 ?
Could you try to delete your config (located in /Users/<username>/Library/tvp animation 11) and try to launch TVPaint Animation again ?
Locked
