mox gallery
Re: mox gallery
Just testing a quick idea mixing a Classic Circle Transition with the new and powerful Brush Spreading (both in the FX stack/TVP11).
First I rendered the transition's frames then used the same layer to spread the leaves/brushes on it.
- brushspread.gif (3.02 MiB) Viewed 39149 times
Re: mox gallery
Nice one. You got the idea behind this FX. We will put some other exemples in the online manual soon.
Re: mox gallery
Still playing with the Brush Spreading
Re: mox gallery
I'm glad you like it.
here is a Before/After result that will be added in the online manual soon (click to enlarge and appreciate the difference)
EDIT :
Here with an other brush created by Léo :
EDIT :
Re: mox gallery
Here are my own attempts :
But Brush spreading works also pretty well with animation (animation by Chad Essley) :
Original animation
After applying brush spread on the sun rays.
Original animation
Re: mox gallery
Brush Spreading = Total playground
Re: mox gallery
Very interesting, this!Fabrice wrote:I'm glad you like it.
EDIT :
Re: mox gallery
i'm testing brushspreading to see if i can use it for animated textured coloring.
but i get crashes when i set dispersion to low. when set to one tvpaint whites out and never comes back to life!
Re: mox gallery
No crash so far, but low "dispersion" value means high CPU usage indeed and it can take ages.Peter Wassink wrote:but i get crashes when i set dispersion to low. when set to one tvpaint whites out and never comes back to life!
I wonder if it would be possible to stop (or pause) a processing during a preview. Tricky.
Re: mox gallery
+1mox wrote:... I wonder if it would be possible to stop (or pause) a processing during a preview. Tricky.
[Esc] key (should) could do that imo .
