smear brush.
idragosani
Re: smear brush.
Post by idragosani »
Wait! Some further tests show it is still happening, even on smear brushes that have no parameter changes, usually darkened colors
ed
idragosani
Re: smear brush.
OK, another oddity, it seems to just be with the large paintbrush, I don't see this with the other smear brushes (the top one is a regular smear paint brush, the second a large paint brush). The fade to black is happening even over top of other colors, resulting in an ugly black spot. This only happens with a brighter color as the first and a duskier color for the second. So maybe something with that brush is acting strange?
e1two
Re: smear brush.
Post by e1two »
hi,
any progress or news on this?
thanks,
e1
Re: smear brush.
Not yet, but thank you for reminding it ;)
Re: smear brush.
It should be improved in the next coming build : 10.0.7, even if not perfect yet. :)
Sewie
Re: smear brush.
Post by Sewie »
I'm just checking; was this problem eventually fixed?
Because here it still occurs in 'smear source' mode, but not in 'smear' mode. (I'm using version 10.0.11)
Re: smear brush.
no, it's not yet, but you are right to mention it again !
Sewie
Re: smear brush.
Post by Sewie »
Thanks Elodie,
Btw, this 'Smear' mode is a great feature, I find. I can see a lot of possibilities in simulating real paint with this one.
Re: smear brush.
Thanks for your kind words ;)
e1two
Re: smear brush.
Post by e1two »
Hi,
I made the original post about a year ago and tried the smear brushes again
on the latest build. However, the problem seems to still be there. :(
Even though smear produces a nice result a lot of the time, it's too unpredictable
as to what result you are going to get.
I eventually bought manga studio at 49$, which has an excellent paint blending
engine. I'm still temtped by tvpaint's excellent animation and storyboarding tools,
but will need to save up a bit more.
e1
Re: smear brush.
Thank you for remind us to correct this !
neonnoodle
Re: smear brush.
Post by neonnoodle »
I'm still having this darkening behavior on TVP11.
Re: smear brush.
I can't reproduce it :o
Can you share the brush parameters ?
Re: smear brush.
It's actually an old problem, which is very hard to fix (and actually hard to explain). It depends on the brush, Anti Aliasing, opacity level, etc.
EDIT (Fabrice) : & processor rounding algorythm
neonnoodle
Re: smear brush.
Elodie wrote:It's actually an old problem, which is very hard to fix (and actually hard to explain). It depends on the brush, Anti Aliasing, opacity level, etc.
Ahh, OK. Thanks for the update, I will proceed with this in mind.
