How to achieve this look?
and with something like this on top.
but what I get is this.
the blue circle looses its 'solid' color and I do not want that.
I am using the watercolor brush and tvpaint 10.
Re: How to achieve this look?
This problem occurs with all transparent brushes. What I do:
- duplicate the top layer
- set it to preserve alpha
- fill it with white
If necessary I duplicate this white layer as well.
Now I have
- top watercolor
- white mask
- bottom artwork
Now I have
- top watercolor
- white mask
- bottom artwork
*update*slowtiger wrote:This problem occurs with all transparent brushes. What I do:
Now I have
- top watercolor
- white mask
- bottom artwork
thank you for the advice. it works to a degree, but the edges as you fill leaves very undesirable results.
and then applying your advice and going around the fuzzy areas with the airbrush
adjusting the flood fill tool helps a bit but i ended up going into the watercolor brush again this time with white as the color and traced along the fuzzy edges(i was not being overly accurate while painting)
I wish there was some other way around in doing this to be honest and done all natively in tvpaint.
Another solution that I am thinking of is on the rendering and compositing side but I'd have to read and research more on that.
If any experts are out there reading this; any links,advice and etc. will be greatly appreciated.
Try this one.
i had the same problem and made a un-transparent (opaque) version
- watercolorssolid2.tvpx
- (1.68 MiB) Downloaded 792 times
wow this is awesome.thank youPeter Wassink wrote:Try this one.
