Annoying: Creating successive instances while I am drawing?
I've been using Tvpaint for over a month now; hitting the ground running in a professional situation.
Sometimes, when I have bookmarked my keys, flipping between them while I draw the inbetween, successive instances are created advancing while I am trying to draw.
I wonder if I've activated something while while holding the Ctrl Shift while flipping?
Has this happened to you?
Remedy?
Thanks.
Remedy?
Thanks.
"I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world." -Albert Einstein
Re: Annoying: Creating successive instances while I am drawi
You're close; Go to the Images tab of the main bar at the top and look at the bottom of the instances menu, .
AH. Click off "auto create instance"? Thanks. But still, that's a weird function
Sometimes it can come handy, for instance when working out straight ahead animation, rotoscoping, or working out preliminary rough poses with no timing in mind...
From your description it sounds to me more, like you accidentally use the "Stroke Animator - Change the current frame during drawing with CTRL" - it's in Preferences panel - used to create animation on the go - never used it, I guess it's good when you need to simulate handwriting or drawing in motion or something.
check this too
The "create new instance" function, which Paul mentioned, can be very useful, and that's actually how TVP worked before. It's more a personal preference, depending on what you work on.
check this too
https://vimeo.com/danas
I see we've now got individual layer control for "Auto-Create/Break", but does anyone know if there's a way to set the default to OFF like in 10.5? I rarely use these attributes, and prefer not to have to remember to uncheck them both every time I create a new layer. (Although I just solved one of my other TVP 11 problems, which is that the Transform tool was applying to all frames, not just the heads as in 10.5, and now I see what was happening because Auto Create/Break were turned on!)
mj
mj
mari jaye
Windows 11
11th Gen Intel(R) Core(TM) i9-11900 @ 2.50GHz
32 GB Memory
1TB HDD/ 1 TB SSD/ 2 TB HDD
Touch
TVPaint Pro 11.7.3 64-bits
Windows 11
32 GB Memory
Touch
Autobreak is now a Preferences feature that can be controlled under the Startup Tab.
Also check out "New" at the top of the Layer Stack where you can create your own favorite presets -- there also you can turn Autobreak off.
Morning, Paul!
I don't see it in the Startup Tab...might it be in Preferences?...
mari jaye
Windows 11
32 GB Memory
Touch
Windows 11
32 GB Memory
Touch
Oh! I see! The Startup Tab IN Preferences, not at the startup of the program!
THANK YOU!
(as usual!)
THANK YOU!
(as usual!)
mari jaye
Windows 11
32 GB Memory
Touch
Windows 11
32 GB Memory
Touch
Yes, it's in the Preferences panel
/Edit : Damn, I wasn't quick enough
Better late than never, Thierry.
mari jaye
Windows 11
32 GB Memory
Touch
Windows 11
32 GB Memory
Touch
