Can we use "smooth" option with "LazyBrush" Plugins?
wonjin
Post by wonjin »
Hi, every one.
I'm working with TVPaint, and i just found "LazyBrush" Plugins.
This is really awesome, but i met a small problem.
I draw the lines with a pencil brush, and than colored with LB trial.
Because of the empty space of the pencil brush in the line, i can see some ugly outline in coloring layer.
Can we use "smooth" option or "anti-aliasing" option with LB?
If someone has an answer for me, give it to me, plz :)
Thanks!!
Have a nice day~ :)
Re: Can we use "smooth" option with "LazyBrush" Plugins?
please can you post a screenshot ?
I'm not sure to understand you.
schwarzgrau
Post by schwarzgrau »
If you use TVPaint 10 you can't use anti-aliasing with LazyBrush.
wonjin
Post by wonjin »
Thanx to your reply!
I'm using TVPaint 9 PRO.
This is the problem what i met.
or
https://mail.google.com/mail/?ui=2&ik=f ... w1896-h835
You see the ugly outline? Especially, the hair line of the girl.
Do i have to retouch it manually? or can i get some solution for this problem?
Ps. Sorry for cropped img :P
schwarzgrau
No I can't access the image. What version of TVPaint 9 do you use exactly?
schwarzgrau wrote:No I can't access the image. What version of TVPaint 9 do you use exactly?
+1
wonjin
Post by wonjin »
Oops :shock: Sorry.
https://www.googledrive.com/host/0B8lX4 ... nMzUzEyRDQ" onclick="window.open(this.href);return false;
Is it work now?
It's TVPaint PRO 9.5.3 ver!
wonjin wrote:Oops :shock: Sorry.
Is it work now?
Everything should work better if you update your old version to the latest 9.5.21 (free update for 9.5.x users)
wonjin
Post by wonjin »
Thank you soooooooooooooo much!! :)
schwarzgrau
Unfortunately the fill tool and therefore also Lazy Brush only works with anti-aliasing with TVP 11. Every version below doesn't use anti-aliasing in the filling.
You can set the smooth value up, but that's not always the best workaround, cause the edges usually gets sludgy before they get smooth.
