TVPaint's "AVI (Internal)" setting
Sewie
Post by Sewie »
I was wondering, the "AVI (Internal)" setting in the Export Footage Window, does it have compression?
Meaning, can I use this as a lossless compression to import in Premiere for editing and then export it out (from Premiere) to PNG or TIFF?
mox
Re: TVPaint's "AVI (Internal)" setting
Post by mox »
There's no compression for the AVI (internal) RGB 24/32 bits mode (not sure for the YUV mode...).
Jerome Lorin
Moxica (playground)
(Win11/TVP 12.0.3 pro)
Sewie
Post by Sewie »
Thanks, Mox.
I've never used the YUV mode. Don't even know what it does...
It makes a difference in color quality. Some rendering codecs prefer YUV, otherwise I don't think there's too much of a difference as far as we should be concerned. I've tried both and don't see a difference.
Paul Fierlinger wrote:It makes a difference in color quality. Some rendering codecs prefer YUV, otherwise I don't think there's too much of a difference as far as we should be concerned. I've tried both and don't see a difference.
Do you know which codecs prefer YUV ?
I made a test rendering of the same scene exported twice, one with YUV and the other with RGB, and to my eyes (on my monitor) the colors of the .AVI exported as YUV looked a little bit more saturated/warmer than the colors of the .AVI exported as RGB . The YUV .AVI file size was slightly smaller than the RGB .AVI .
I had the same experience with with the Sony YUV Codec and there's a Sony 10-bit YUV Codec too which I never tested because in spite of the pleasant results I was worried to adopt YUV only because so few people use it and it might lead me into some unforeseen complications down the line because the difference wasn't that great anyhow.
This is strange: On September 1 I made some tests , exporting .AVI files from TVPaint using RGB and YUV format . Both formats played fine in Quicktime Player 7 PRO . (as I said above: "the colors of the .AVI exported as YUV looked a little bit more saturated/warmer than the colors of the .AVI exported as RGB .") Now today (Sept. 29) I tried exporting to .AVI with the YUV mode , but this time when I tried to play the .AVI file it shows as all black frames in Quicktime Player 7 PRO . (VLC player will open it.) It's not a big deal really, but it bothers me . WHY did it play before , but now it doesn't play in Quicktime ? I haven't changed anything on my end that I am aware of.
Anyone else on Mac OS: can you export from TVPaint with the Internal .AVI export engine set to YUV mode and open the video in Quicktime Player 7 ?
furushil
Post by furushil »
D.T. Nethery wrote:Anyone else on Mac OS: can you export from TVPaint with the Internal .AVI export engine set to YUV mode and open the video in Quicktime Player 7 ?
I tried it and it is also all black here because of missing components.
Thank you for confirming that. It's good to know it's not just me.
We bought Quicktim Pro 7, Thierry should do the test soon.
Confirmed.
I exported an AVI in YUV with TVPaint and tried to read it with QuickTime 7 Pro and with QuickTime 10.4, it didn't work.
No issue at all with VLC Media player, and even Windows Media Player and the Win10 application for videos can read it without issues.
Thierry wrote:Confirmed.
Ok, thanks for confirming that.
I can only guess that with my previous experiment with exporting an .AVI in YUV mode I must have made a mistake ... I probably thought I had switched it over to YUV mode ,but I still had it set to RGB mode , so that's why it opened ok in Quicktime 7 Pro. I think I fooled myself. :oops:
It's really not a huge issue for me (whether or not I can use .AVI in YUV mode) . RBG mode .AVI is fine for my purposes .
If I needed to use YUV mode for some reason I'll just open it in VLC (and can use VLC "Convert" to convert it to H.264 .mov or .mp4 if needed). It is probably not worth the time emailing to ask Apple to fix QT Pro 7 to play YUV mode .AVI's because I doubt they'll respond or do anything about it. I'm just glad QT Pro 7 will open and play .AVI in Motion JPEG mode and in RGB mode.
