First post btw, HI THANKS HI!
* I know you'll never get 100000 textures in there but a cycle of many works great.
slowtiger wrote:I put some 3 or 5 textures into an animated layer and loop it, then set this to mask and draw on a different layer. You can set the paper layer to invisible, it still works. Only problem is you can't easily adjust the paper's strength, so you have to test a percentage firs, then make it permanent within the layer by merging with white.
Oooooh reeeeally? I shall try that in the morning. So the scan cleaner will give graduated alpha values to the image I assume?slowtiger wrote:Use the scan cleaner on the textures?
exactly,daninski wrote:Oooooh reeeeally? I shall try that in the morning. So the scan cleaner will give graduated alpha values to the image I assume?slowtiger wrote:Use the scan cleaner on the textures?
