Has anyone noticed this?:
When working with the Library, usually dragging images into the library, TVP starts eating away the RAM of the system. I don't know what it does with it but in my system it slowly fills up all 32GB until it crashes.
Whenever I load images into the library I often also place them in my Project Window via the Guideline Panel > Support > Image. After that I've noticed my RAM slowly filling up until eventually I get a low memory warning from Windows and TVP crashes. It happened quite a few times for me.
It's a pretty serious bug, I think.
Image Library RAM bug
Re: Image Library RAM bug
We're going to run some tests.
In the meantime, it would be good for us to have more informations, like :
- Does it happen with the latest TVPaint Animation 11 version ? I see in your signature that you are using 11.0, but the latest one is 11.0.2
- Does it happen with the 32-bits and 64-bits versions or only the 64-bits ?
Thanks Thierry.
Yes, in 11.02, I'll update my signature. I always try to update whenever there is new version out.
I haven't tested the TVP 32bit version because I don't have it installed. (I never looked back since 64bit came out )
Thanks so much.
