Transform Layer
Jourdan Biziou
Transform Layer
Post by Jourdan Biziou »
Hi Everyone,:)
Ive been trying to find a way to Transform all animation on a layer. I want to move not just one drawing, but re-frame all drawings on a layer together to recompose where my action is taking place. My characters head is clipped a little and just want to move all the action down a bit.
Tried various ways but no success.
something simple I am missing ? please help,, thanks
~ Jourdan ~
~ I think therefore I draw ~
Win 7 64bit, Nvidia Quadro K5000, 34 GB. TVpaint 11.0 pro 64bit, Wacom Cintiq 27 HD, Intuos 3
Jourdan Biziou
Re: Transform Layer
Ahhhhhhh
Solved !! :)
After searching more I found that I could use the Key Framer to move everything. but in under the options had to select / Currant Layer/ All Instances/ Frames. Then it processed and moved.
While this works. is there a more direct method ? simply select a layer and move at once in real time ?
thanks,,
~ Jourdan ~
Re: Transform Layer
Select one frame. Move with pan tool. Select remaining frames, hit enter = re-apply.
or:
Select one frame. Move with transform tool, hit enter to apply. Select remaining frames, hit enter, hit enter.
Jourdan Biziou
Re: Transform Layer
Ahhhhhh !!
thank you Slowtiger !:) thats great ,, works perfect !!
