paintbrush
paintbrush
paintbrush
making use of Luma invert Stamp to apply A and B colors
________________
open the paintbrush.zip file
save the paintbrush.bin file and paintbrush.data folder
in a "tvpaint custompanels" folder
then in tvpaint create a new custom panel tool bar
and import the paintbrush.bin file
voila...there you have the brush
enjoy
this is what the actual brush looks like.<br />for its settings i've chosen to set anim behaviour to random
paintbrush.ZIP
(1.96 MiB) Downloaded 848 times
mox
Post by mox »
Nice! Thanks Tantalus :]
Jerome Lorin
Moxica (playground)
(Win11/TVP 12.0.3 pro)
fabrice_
Post by fabrice_ »
:shock: super cool brush !!!! GREAT IDEA 8)
electro-box
Post by electro-box »
Yes super ! Very strange effects !
So is this possible to see a day the come back of Gradient cycling / shifting animation as old days Dpaint do ?
CG community :: www.tdt3d.com
natali
Post by natali »
Heya,
I really want to import this brush, but I can't seem to find a way to do it.
The problem:
When I select the brush and click ok; there is nothing added to my list.
I have Windows instead of a Mac, could this be the problem?
fabrice_
Post by fabrice_ »
hi natali,
It works on both Mac and PC. Use your right mouse button on the custom panel icon to load a new panel. (select the bin file)
natali
Post by natali »
Hello Fabrice,
Thank you for your reply :)
I tried to do that, but the brush does not go in the custom panel. The file has a windows icon on it- is that suppose to be like that?
Also, when i download the brushes here, it comes as a .rar format (with three books). Is that right? :(
natali wrote:Also, when i download the brushes here, it comes as a .rar format (with three books). Is that right? :(
it should be a .Zip file, extract it, and you should get a folder "paintbrush.data" and a "paintbrush.bin" file (see pict.);
in tvpa, RMB on the Custom Panel icon, go to "load a new tool bar" and choose the .bin file.
natali
Post by natali »
Yeah, thats right :)
And i have done that, but the .bin file has a windows icon on it, instead of the blue icon on yours.
(I have extracted it)
How come? :(
natali wrote:Yeah, thats right :)
the icon doesn't really matter ...
haven't you try the next step ?
ZigOtto wrote:...
in tvpa, RMB on the Custom Panel icon, go to "load a new tool bar", browse and choose the .bin file.
natali
Post by natali »
Yes, i have done every step that you all have given me, but it still doesnt work. :(
When i have clicked the icon, and click ok, i go back to tvpaint/mirage, but there is nothing in that 'gray surface'.
Patrice
Post by Patrice »
Hi Natali,
You need to have one the last version of TVP Animation to import Custom Panel. Which version have you? Can you give me the date writing in the "About" panel?
You speak about tvpaint/mirage... Have you TVP Animation or Mirage?
Ex TVPaint Team
Hoi Natali,
mocht het met de laatse upgrade van tvpaint niet lukken
kan het ook nog zo:
laad het 'paintbrush.dip' bestand (hieronder) in tvp met 'load'
in het 'import Footage' scherm kies je de 'New Custombrush' tab (zie plaatje)
nu heb je hem als custombrush
stel vervolgens de goede settings in in het custom panel (zie andere plaatje)je kunt deze settings natuurlijk aanpassen naar je wensen.
shift beinvloed bijvoorbeeld hoeveel de brush mengt met bestaande kleuren.
succes!
_______________________________________________________________
Hi Natali,
in case upgrading doesn't do it
there is this option:
load the 'paintbrush.dip' file into tvp with 'load'
in the 'import footage' window choose 'new custombrush tab (see image)
now you have it as a custombrush
make the right settings (according to the second image)
you can adjust them to your liking offcourse
shift f.i. determens the ammount of mixing with other colors
good luck!
paintbrush.dip
(3.28 MiB) Downloaded 550 times
natali
Post by natali »
Hey, dankje :)
I have tried to do that, but nothing happens again :(
This is how the .bin file looks like, it is presented as a VLC media file (.bin) type- is that right?
natali
Post by natali »
Patrice wrote:Hi Natali,
I apologize, I often mix up 'tvpaint' with 'mirage', so i wasnt sure what to call it.
I own TVPaint 8.1.1. :)
