paintbrush
- malcooning
Natali,
Windows or Mac, most of us have worked on both and imported and exported brush bins successfully. rest assure that you have everything that it takes to import the brushes. something in the way is not working right, and it could be even a very little step that you are missing. The symptom you are describing (that when you import the file nothing is added to the panel) happens when the bin file you are directing TVPaint to is not the right one, or is still in the archived file.
Don't worry about VLC or any other icons, they only indicate which program is associated with certain file types in your windows. as long as you follow our suggestions these associations will make no difference whatsoever.
The screen that you posted earlier shows that you are looking in the .zip file. this means that you haven't extracted the file. I suggest this:
1. put the downloaded file on the dektop
2. double click on the file.
3. select ALL files (one file and one folder)
4. drag them onto the desktop (and make sure they are there.
now, in TVPaint:
1. make a NEW custom panel/toolbar.
2. right click on the new toolbar, and choose import
3. choose the desktop as location, and select paintbrush.bin file (not the folder)
any results?
now, in TVPaint:
any results?
hi Natali,natali wrote:Hi,
Thank you for responding.
I am sure that the version i have is not the problem. There is someone who owns the same version as i do and managed to do it- he tried to help me, but we got stuck to the idea that perhaps it has something to do with that i own a Windows computer and he owns a Mac.
I think it's a tvpa version matter...
for exemple, the mode of this brush is "luma inverted", but this mode is not available in tvpa 8.1.1 ...
can you try to download, extract, and import this tweaked bin file? (I think this one should work for you too)
please, report here the result (successful or not).
ps: I've compressed it in .rar format, to avoid to confound it with the original one.
- paintbrush.rar
- (1.77 MiB) Downloaded 392 times
Thank you ALL for helping!
and thank you Malcooning for the steps.
Now i know what went wrong- i didnt drag ALL the files from the .rar folder, just the .bin file and not the rest. So, it was just a clumsy mistake... :S
Thank you ZigOtto for your .bin file, i have also managed to import that type as well
Sorry for the confusion.
Ta,
Natali
Ta,
Natali
- malcooning
paintbrush mode ?
I'm also curious about what "mode" did you get straight after importing the zipped .bin file as new custom panel?
was that "Color", "Alpha", "Luma", or "Hue" ? (see attached pict.)
because when "Color" doesn't display the brush-preview, I've noticed that swapping in one of the "Stamp" mode,
then again to "Color" mode, force the brush to appear ...
- paintbrush.png (17.22 KiB) Viewed 4560 times
Re: paintbrush mode ?
I tried again to check which mode is available by default, i got Alpha (and it worked fine with any other mode from TVP Animation)ZigOtto wrote:I'm also curious about what "mode" did you get straight after importing the zipped .bin file as new custom panel?
