Hey!
I need to be able to rename a paper (no option in the RMB menu), we can onnly choose a name while creating it.
Also no way to import or export papers, for exemple if I have a brush that works with my own paper, I would like to either be able to embed it in my brush button or to be able ton import/export the paper for other users in the production to use it without having to recreate it from an image.
Maybe a george command to import current brush as a paper could be nice as a first help to script this.
Nathan
Rename Paper Name + Import Export
- NathanOtano
Re: Rename Paper Name + Import Export
It is possible to access all papers in the file system (on Mac that's TVP/show package content/Contents/Resources/papers), there you can rename, add or delete papers. (Note that with each new TVP installation you'll get the default paper folder, so you have to manually update this.)
- NathanOtano
So maybe there is a way to save a cutbrush at the right place to create your paper... Interesting thanks
