I want the auto break function to be off by default, just like it was possible in 10.5
I tried to do it in Preferences>Startup, but it doesn't seem to change anything...
How to turn off Auto Break by default in TVP11? Topic is solved
https://vimeo.com/danas
Re: How to turn off Auto Break by default in TVP11?
Auto-break is no longer a global setting, but a layer-specific setting.
Changing the option in the Preferences panel > Startup only works for the default layer that you have when you open the software or create a new project.
You should deactivate the option in the Layer Preset Manager :
Ok, I see - why did you remove it globally? is it because of the new functionality syste? I would really appreciate if it was a global option too...
- NathanOtano
Also in some cases, like when exporting a CTG layer, TVPaint still creates layers that autobreaks.
