Pen cursor problem (changing to an arrow)
- David_Fine
Re: Pen cursor problem in 11.03
Happened again. Have to restart my whole computer to clear it up. Seems to be about once a week. I am posting here to give a sense of the frequency. It is really interruptive and as I say, for me, only since this latest .03 version.
David Fine
Snowden Fine Animation Inc.
Vancouver, Canada
Vancouver, Canada
David, what about 2dbert said here? Is iTunes or youtube running in the background while you are working?2dbert wrote:This may not help at all, because my setup is still as listed in my signature, but I remember realizing some time ago what seemed to cause the cursor to turn from point to arrow (in TVP 10).
I believe I had youtube running on auto play in the background whilst working in typ, some old radio show just for some background noise, and whenever auto play put on the next episode in youtube, the cursor would turn into an arrow in tvp. I thought it was strange that the one thing would influence the other, but then I don't know an awful lot about these things and that's what seemed to be the case, or else it must have been a quite persistently ongoing coincidence.
So if this isn't completely out of the question, and if you had some player or iTunes or something of the sort running whilst working at the time the cursor payed up, you could try to reproduce that bug in such a way.
If it happens again, could you try to quit all programs except TVPaint and see if the cursor changes back?
- David_Fine
I seem to have overlooked that suggestion, but I will indeed try and report back. Thanks!
David Fine
Vancouver, Canada
Vancouver, Canada
Thank you for quoting 2dbert message, I has missed it. I think this can be a part of the problem because I had some cursors mistakes when I was listening to youtube o itunes. But it lasts a few seconds before switching to the normal cursor. So, still have no clue.furushil wrote:David, what about 2dbert said here? Is iTunes or youtube running in the background while you are working?2dbert wrote:This may not help at all, because my setup is still as listed in my signature, but I remember realizing some time ago what seemed to cause the cursor to turn from point to arrow (in TVP 10).
I will test it anyway on other computers and see whether we can definitely trigger this bug, just like David experiences it.
- David_Fine
This may be a related issue I just discovered. I always set my eraser to be a red pen, set on erase. That way, when I use it with the rocker button on the pen, it changes to a red blob, which is a nice visual to tell me that I am using the eraser and also the size of it. (That was a tip from Paul F.) I just noticed that the erase no longer shows the red colour circle, just the point (I have it set to point). Now I can't tell the size of the eraser, which makes careful erasing more difficult. How did this change?
I then went to preferences to try changing from the point to circle to see if that would help, but instead of getting a circle, I get the arrow pointer. The same arrow pointer I get which I have been writing about earlier and which I have to restart the computer to go back to the point. In this case though, when I go back to prefs and change from circle to point, the arrow does change back to the point.
So lots of strange behaviour for me with the pen cursor. Not being able to tell the size of the eraser I am using is really a drag and I'm not sure why it worked before, but not now.
David Fine
Vancouver, Canada
Vancouver, Canada
I will answer a part of the question posted here : http://forum.tvpaint.com/viewtopic.php? ... 034#p94077" onclick="window.open(this.href);return false;
So no, this cursor issue is not fixed yet for the reasons I've already given (cannot reproduce it).
When the arrow is back, what if you change the cursor in tvpaint preferences ?
I just had this issue again but when I quit safari and photoshop the issue was resolved and the cursor was back to normal.
David, I recommend you to quit all applications except for TVPaint and see if the cursor changes back.
- David_Fine
The problem has not happened for a while and it just did, so I started by quitting Photoshop and... It fixed it!! So that's really interesting. Good to know there is this fix, but I wonder what causes it because it's only happening within TVPaint. Thanks for the tip about Photoshop. I did not need to quite Safari to fix it.
David Fine
Vancouver, Canada
Vancouver, Canada
I will ask our admin to rent Photoshop for a month and see if we can fix that.
Great tip indeed ! I don't know if it will be the solution to fix it, but at least it's a good step forward !
- schwarzgrau
I don't know if this helps in any way: I started rendering something in After Effects CS6 and the cursor became this kind of loading curser, where it fills with white and then with black....some kind of loading cursor. I hided After Effects to draw in TVPaint and noticed that the cursor is still this loading cursor, which was pretty annoying. I switched back to After Effects, than again to TVPaint and I got my old cross back.
This seemed to me like After Effects would control the appearance of the cursor in some way.
Monday , December 19 , 2016 -
For the record , this issue of the pen cursor randomly changing from Cross to Arrow was just reported to me by one of the other artists working on the project that I'm working on. He wondered if I had encountered the issue and how to fix it .
Here is the odd thing: nothing has changed on his Mac that he knows of ; he didn't recently update the OS or install any new software , but all of a sudden after months of using TVPaint , he now has this annoying issue of the pen cursor changing from Cross to Arrow .
I forwarded him the tip to turn off Photoshop and other apps , and to not have YouTube or iTunes running in the background while using TVPaint to see if that fixes the pen cursor issue . Maybe that will help him, but that seems like a very annoying workaround ... why should anyone have to not listen to iTunes or YouTube while they are working ? Many people listen to music or podcasts while spending long hours working at the Cintiq , so to be told: "try working without iTunes or YouTube running in the background" is more than a little bit disappointing as a "fix".
The problem seems to come from notification : when I use itunes and music switches, I get the arrow and I just have to click on an icon to get the cross cursor back. I don't have any trouble with Youtube.
Just to keep you posted :
Someone just told me having the same issue on Mac 10.10.5 (Yosemite). He is not listening to Youtube or iTunes : only Photoshop, Chrome and Firefox are running in addition of TVPaint.
Seems like there is sort of a conflict between Adobe and TVPaint, we will have a look on it.
Elodie wrote:The problem seems to come from notification : when I use itunes and music switches, I get the arrow and I just have to click on an icon to get the cross cursor back. I don't have any trouble with Youtube.
You don't even need to click on the icon, if you just move the arrow over your controls or brushes it turns back into the crosshair.
http://www.daninski.com
