Clearing image marks cannot be undone
Hi
I had a lot of image marks on different layers. I wanted to clear them from one layer, so I right clicked the layer and pressed "clear all image marks". Frankly, I didn't expect it to delete all image marks from all layers. Now here is the saddest part - it cannot be undone...
Going back putting them all again is a lot of work...
I believe this could be somehow fixed to be more intuitive - adding "clear marks from current layer" into the right click menu would really help, and an undo option for this would be also nice, although I understand it might be not easy code-wise. (I know I can delete image marks on one layer from the image marks menu, but it means I have to open this menu each time, or create more shortcut buttons on the interface...)
https://vimeo.com/danas
Re: Clearing image marks cannot be undone
Joanna told me the same and I totally agree : this behaviour is counter productive and it should be undoable.
- schwarzgrau
The image marks are sooooo useful, but to me it seems they didn't get much attention in the past. Two years ago you couldn't crop a project without loosing all your marks, one year ago you still lost all marks if you modified the project and now you still loose it if you merge two layers.
I know there is a lot of stuff to do and everybody thinks his problem is the most important one, but some of us use image marks excessively to keep track of everything, so it will a total chaos to loose them.
But you already agreed, so I'm just bleating around
all trueschwarzgrau wrote:The image marks are sooooo useful, but to me it seems they didn't get much attention in the past. Two years ago you couldn't crop a project without loosing all your marks, one year ago you still lost all marks if you modified the project and now you still loose it if you merge two layers.
my scene, for example, of 300 frames and 3 character layers - book marks help me keep track of keys and other stuff, etc. so literally hundreds of them in 2 colors at least. loosing them is no fun I guess some animators don't use them much, but some do, and for those who do it's crucial,
thanks ElodieElodie wrote:Joanna told me the same and I totally agree : this behaviour is counter productive and it should be undoable.
Thanks! This will be a big help.
Xavier, you are like Lancelot on a white horse - bringing light and order to the world of suffering! I'd like to praise your name and spread word of your deeds and hope your masters will dully appreciate and compensate your accomplishments accordingly - (preferably materially )
thanks!
- schwarzgrau
Oh great! Will this also work if you clear the image marks of a whole layer at once?
Do you mean using the "remove all image marks" menu ? yes, it works ^^schwarzgrau wrote: ↑23 May 2021, 02:34 Oh great! Will this also work if you clear the image marks of a whole layer at once?
Thanks, I appreciate. I like the fact that we can interact with each other and get real feedbacks (positive and negative) ! It is very valuable to work for such a community of users.Soom wrote: ↑22 May 2021, 13:27 Xavier, you are like Lancelot on a white horse - bringing light and order to the world of suffering! I'd like to praise your name and spread word of your deeds and hope your masters will dully appreciate and compensate your accomplishments accordingly - (preferably materially )
thanks!
I think here on this board we all want TVPaint to live on. So I do what I can to improve the software
This one was not so hard in the end. The multiply blending mode is at another level, for instance !
hah, I didn't get to using those yet! )
