about light table off pegs behavior Topic is solved
There is a tiny strange behavior when using the off-pegs on the light table. whenever a peg is altered, all other selected pegs shift in color - become darker. First I thought it's a glitch, but then I thought it might have been done on purpose, which is a good purpose, but wouldn't it be more intuitive that instead all other drawing shift colors - the selected drawing would change?
thanks
thanks
https://vimeo.com/danas
Re: about light table off pegs behavior
You are right - sorry! here they are.Fabrice wrote:screenshot please.
Without using out of pegs: As soon as I select one frame for out of pegs manipulation, all other frames become darker: Here you can see the selected frame did not change in color. I like the idea of distinguishing the manipulated frame, but IMHO it should be vice-versa
- schwarzgrau
I noticed the same behaviour
Yeah, I recognize it too.
This bug is even more serious - I realized it when working with more solid dark colors. When one of the frames on the light table is shifted, the other one overlaps the drawing (look at the screenshot). Interesting, that if both frames are shifted, it behaves normal again.
- schwarzgrau
Maybe you have turned the lighttable to "front-mode".
If you click on Instance see if "Blend to front" is checked.
- Bildschirmfoto 2016-10-12 um 19.43.12.png (16.32 KiB) Viewed 21550 times
I have exactly the same problem. I've tried both, with "blend to front" checked and unchecked and to me it just looks the same. Are there any other options I could play around with?schwarzgrau wrote:Maybe you have turned the lighttable to "front-mode".
OK ! I understooooood !
So yes, indeed, there is a weird behaviour when you enable OOP on 1 instance (image becomes more opaque, for no reason).
To the To do list !
To the To do list !
Exactly!!! hooray, thanks!Elodie wrote:OK ! I understooooood !
To the To do list !
It was really simple to get, but I don' know, I was very slow on this one...
EDIT : fixed in the v11.0.6
https://forum.tvpaint.com/viewtopic.php ... 450#p98450
