Export TVPaint - Import After Effects 1.0.4
schwarzgrau
Re: Export TVPaint - Import After Effects 1.0.3
Post by schwarzgrau »
Sure. And thank you again.
Animatic_v05_0_test.zip
(6.34 MiB) Downloaded 594 times
Mads Juul
Post by Mads Juul »
schwarzgrau wrote:Sure. And thank you again.
It works here.
So I can't find the bug sorry :(
NathanOtano
Post by NathanOtano »
Something stupid but the script wasn't working for me for a while and i tried all i was able to find on the topic, and I just noticed with a teacher that it was because our after effect at school is in french and the script in english. I had to replace "footage" line 8 in the javascript with "Métrage" in french.
I thought it can be usefull to mention it here among the other bugs.
NathanOtano wrote:Something stupid but the script wasn't working for me for a while and i tried all i was able to find on the topic, and I just noticed with a teacher that it was because our after effect at school is in french and the script in english. I had to replace "footage" line 8 in the javascript with "Métrage" in french.
that mighht explain it didn't work in japanese either. thanks for the tip !
schwarzgrau
I got some problems with the After Effects import script since some while. Today I exported a scene and got this Error message while running the script inside of After Effects "MESSAGE 2 : Please Select a PNG Exported From TVPaint" or sometimes "Please Select a PNG Exported From TVPaint 1". I checked all layer names and exported again, checked the files and their names. Everything seems right.
Then I tried to import an old folder (which I already imported a while ago) and got the same error message. I thought maybe it has something to do with my folder structure and moved the folder in my root directory, but I still got this Error.
Maybe it has something to do with OS X 10.10 Yosemite, cause I'm not sure if I ever used your script successful since updating.
Mads Juul
Post by Mads Juul »
schwarzgrau wrote: Maybe it has something to do with OS X 10.10 Yosemite, cause I'm not sure if I ever used your script successful since updating.
Maybe Adobe have changed something in the scripting. At this point I'm not subscribing to Adobe anymore and I don't have Mac anyways. So as it looks now I will not change the script in the near future.
But if someone is using it and knows how to Script then please make changes and upload it here.
Sorry I can't help
Kind Regards Mads
So for those who wants the script to work with a Japanese After Effect, you have to change the 8th line of the script :
if(lele=="Footage"){
To :
if(lele=="フッテージ"){
After that, it should work.
(Thanks to Hironori Takagi for the information)
NathanOtano
This is a modified version of the script by Duduf when he was at our school for our annecy films. It should work for all languages, and we also added an effect on each layer that detects each instance. It does nothing by itself but you can copy the keys on a time remap, for exemple. If you want your compositing to follow the exposures instead of applying on all images (and if so it's also faster to calculate).
MJ_TVPAINT_IMPORT_1.0.4.rar
(2.73 KiB) Downloaded 613 times
schwarzgrau
Very helpful, thank you (and Duduf)
skeh
Post by skeh »
thanks!
it's very useful! :D
macpro 2010 3.46 40gb
mbpr 2014 2.8 16gb
with cintiq 22
tvpaint pro 11 on mac
EmBocca
Post by EmBocca »
Hi Mads,
Thanks for the script it's really great !
Did you make an update version for Tvpaint pro 11 ?
I can't find it.
Thanks a lot.
EB
schwarzgrau
It still works in TVPaint 11, at least for me. Have you tried it?
EmBocca
Post by EmBocca »
Yes I've tried but it's not really stable.
I saw there is an update 1.04 but the file is damaged I can't extract the archive .rar
I work on max osx
Did somebody already solved the problem ?
Thanks a lot !
schwarzgrau
I don't know what you exactly referring to when you ask if someone fixed it. 1.0.4 is basically 1.0.3 with some small changes made by Nathan and Duduf, it seems a bit more stable to me, but maybe that's just my imagination.
However the archive seems broken, so I uploaded the version I'm using for you. Hope this helps.
AE_TVPAINT_EXP_IMP_1.0.4.zip
(9.47 KiB) Downloaded 616 times
EmBocca
Post by EmBocca »
Great, it works well !
Indeed the file was corrupted.
I'm so happy now.
Thanks a lot !
