Hey!
Could be nice if we could export the slate with the camera view option and not just the project view
Nathan
Exporting slate with camera view Topic is solved
- NathanOtano
Re: Exporting slate with camera view
it's already available. Or maybe did I misundertand you ?
- NathanOtano
This is weird but I have a black frame, or a cropped image depending on the project. And the logo and name of the author dissapears. And i just made it work with another project so I guess it's a bug. Let me dig into that
I have the same issue using Slate .NathanOtano wrote:This is weird but I have a black frame, or a cropped image depending on the project. And the logo and name of the author dissapears. And i just made it work with another project so I guess it's a bug. Let me dig into that
We confirm the bug Nathan is describing.
*Added to the todo-list*.
I have also moved the topic to the Technical Support section of the forum, which is more appropriate.
Any updates on this? Or work arounds? I have the same problem.
TVPaint Pro 11.0.6 32-bits
macOSSierra 10.12.3
macOSSierra 10.12.3
Just had a look at slate for the first time in ages. I did try to use it a while ago but it was very messy with write framing and logos. I had been exporting to AE or FCX to put the frame counters on, until I just checked again and it's all been tidied up and fixed. It's spot on now. So just wanted to say thanks, and good job. Made me really happy It's the little things isn't it
http://www.daninski.com
you are welcome.
It's indeed fixed since 11.0.7
