Exporting slate with camera view Topic is solved
NathanOtano
Post by NathanOtano »
Hey!
Could be nice if we could export the slate with the camera view option and not just the project view :)
Nathan
Re: Exporting slate with camera view
it's already available. Or maybe did I misundertand you ?
NathanOtano
This is weird but I have a black frame, or a cropped image depending on the project. And the logo and name of the author dissapears. And i just made it work with another project so I guess it's a bug. Let me dig into that
NathanOtano wrote:This is weird but I have a black frame, or a cropped image depending on the project. And the logo and name of the author dissapears. And i just made it work with another project so I guess it's a bug. Let me dig into that
I have the same issue using Slate .
We confirm the bug Nathan is describing.
*Added to the todo-list*.
I have also moved the topic to the Technical Support section of the forum, which is more appropriate.
dschutten
Post by dschutten »
Any updates on this? Or work arounds? I have the same problem.
TVPaint Pro 11.0.6 32-bits
macOSSierra 10.12.3
Should be fixed on next update (v11.0.7).
daninski
Post by daninski »
Just had a look at slate for the first time in ages. I did try to use it a while ago but it was very messy with write framing and logos. I had been exporting to AE or FCX to put the frame counters on, until I just checked again and it's all been tidied up and fixed. It's spot on now. So just wanted to say thanks, and good job. Made me really happy :D It's the little things isn't it :D
http://www.daninski.com
you are welcome.
It's indeed fixed since 11.0.7
