Audio problem
A1
Audio problem
Post by A1 »
I seem to have a problem with the audio. It does not seem to play when i hit the play button.
I only get sound when i set Audio Jog to 'always'. And even then i can only scrub, not play. I tried mp3 and wav. , both files that never gave problems before.
I've loaded scenes that worked fine previously, but have the same behavior
as stated above.
Some new button I'm overlooking perhaps?
Any help would be greatly appreciated, I'm kind of in a jam right here. :(
weird ... Mac or PC ?
- have you a layer longer enough, I mean at least as long as your soundtrack ?
- did you get the yellow wave form displayed in the Layer window ? (see pict.1)
- have you the sound gadget enable (enlightened) ? (see pict.2)
A1
Post by A1 »
That's way to silly. I didn't enable the sound button. Now it works fine.
Thanks a million for your time and 'sound' advice!!
:oops: :oops: :oops:
cresshead
Post by cresshead »
hey you not the only one rto foerget to turn the audio speaker button on! :oops:
wuld be nice if tvpaint could load/play standard itunes files..currently i convert to mp3 to get it to work.
Patrice
Post by Patrice »
TVP Animation (Pro) can load standard .wav and .mp3 file thanks to the system library. All other format are not default one (and since it is an animation software) we only support standard audio formats.
Ex TVPaint Team
