guideline "line angle" bug in TVP standard version Topic is solved
I think there is a bug in the 32bit version or rather the standard version of TVPaint.
I'm not able to create a "line angle" guideline properly. As soon as I set the guideline, the blue line lags behind the cursor.
Here is a video that shows the problem:
https://www.dropbox.com/s/yeevqcwj6njwo ... v.zip?dl=0" onclick="window.open(this.href);return false;
Re: guideline "line angle" bug in TVP standard version
Huh ?! What a weird stuff !
I cannot reproduce it with 11.0.3 Standard Edition...
If I hold shift, it forces the line angle to be vertical or horizontal, but not in 45° diagonal (So I cannot say it's because Shift is triggered on your keyboard)...
My student brought this to my attention. So, it is not just me.
I tried it out in the TVP Pro 11.0.3. 32 bit version and I get this weird behavior.
It works fine in the 64 bit version.
Is your student on Mac too ?
Not happening on Windows 10.
Elodie and I tried to reproduce it but without success, either on standard version or pro 32 bits version.
Mac Developer
He is using OS X Yosemite Version 10.10.5.Elodie wrote:Is your student on Mac too ?
Ok, so that would be Mac issue, but neither Jeremy or I can reproduce it...
Someone passes me aspirin, I'm tired of these "random issues" that pops in some people's computers only...
My student found out that it is a wacom/stylus issue.
When using the trackpad everything works fine but with the stylus there is the strange bug as described above.
It is basically almost impossible to use the guidelines.
He is using a Cintiq and I am using an Intuos 4. We both have the same issue in TVP Standard or TVP Pro 32 bit.
Maybe that helps
Maybe that helps
Have you uninstalled Wacom drivers and install new ones ?
on your video at the beginning, there is a black circle around the cursor.
does it comes from a third party software ?
He has reinstalled his complete OSX system recently, I will ask him if the drivers are updated now.Elodie wrote:Have you uninstalled Wacom drivers and install new ones ?
I can try later to uninstall the drivers and install new ones.
Yes, this is just quicktime indicating a mouse-click with a circle when you record a screen capture.Fabrice wrote:on your video at the beginning, there is a black circle around the cursor.
TVP 11 Pro (11.0.8-64 bits), MacOS 10.13.6 - Wacom Cintiq 27 QHD
