timeline disappeared under 'project' tab Topic is solved
bazookash
Post by bazookash »
I don't see timeline when I am on the 'Project' tab. It is very inconvenience.
does anyone know, if there is anyway I can go back to default interface set up or just re-activate/enable Timeline bar?
I attached image below
Thank you so much
Re: timeline disappeared under 'project' tab
bazookash wrote:Hello,
Thank you so much
Maybe I misunderstand you , but the way to view the Timeline is to click on the Clip Timeline tab instead of the Project tab.
bazookash
Post by bazookash »
thank you so much for the reply D.T. Nethery
I was talking about timeline/playback bar in Project tab , not in the timeline tab.
I screen captured from different computer to show you what i meant
o0Ampy0o
Post by o0Ampy0o »
Try clicking the inverted pyramid icon located in the upper right corner of the drawing/scene window.
That control panel is called the Remote.
It can be toggled in and out.
Remote Switch2.png (2.63 KiB) Viewed 18368 times
bazookash wrote: I was talking about timeline/playback bar in Project tab , not in the timeline tab.
Ok, I did misunderstand what you were asking about .
It is as o0Ampy0o says in the post above: Click on the inverted pyramid icon located in the upper right corner interface . That will goggle the playback bar on and off . You must have clicked it accidentally and did not realize it or you may have accidentally selected "Inlay View" from the View menu , which will also toggle off the playback bar . If that happens just deselect Inlay View under the View menu.
bazookash
Post by bazookash »
thank you so much o0Ampy0o and D.T Nethery
It was 'Inlay' .
now i have remote on my tvpaint. oh yes
thank you masters!!
