Fade in affect? Topic is solved
- cyrus rebello
Fade in affect?
If there's a fade in and out affect, is it in the FX stack? and on what extent is it customize able?
Re: Fade in affect?
Yes. FX Stack > Transition > Fade . It can be any length that you want and you can keyframe the percentage of fade (transparency) over the length of the fade , so yes, it can be customized.cyrus rebello wrote:If there's a fade in and out affect, is it in the FX stack? and on what extent is it customize able?
https://www.tvpaint.com/doc/tvp11/index ... ition-fade
But here's the quick and easy way to make a fade:
On a new layer add two frames . Flood Fill the first frame with Black . Second frame is blank. Now drag and stretch second frame to
the desired length of the fade (let's say 24 frames) . This will make the Increase Layer Length panel pop up. Select Stretch >Interpolate.
The result is a fade-in (to do a fade out , reverse it) .
Re: Fade in affect?
Here's my universal FadeIn-FadeOut.bin file. To use it, simply load it in FX Stack / Multiple FX and check either of the two effects: FadeIn8 or FadeOut8. The default size is 8 frames, but either can be positioned and stretched to any frame count. The Speed Profile curve can be adjusted to weight the rate of fade.
- FadeIn-FadeOut.zip
- (574 Bytes) Downloaded 1047 times
Re: Fade in affect?
Hi, Sven -Svengali wrote:Here's my universal FadeIn-FadeOut.bin file. To use it, simply load it in FX Stack / Multiple FX and check either of the two effects: FadeIn8 or FadeOut8. The default size is 8 frames, but either can be positioned and stretched to any frame count. The Speed Profile curve can be adjusted to weight the rate of fade.
When I try to import the Fadein-FadeOut.bin it says "Bad or Corrupted Bin File".
Re: Fade in affect?
Hi Dave, When I download it here, it seem to load ok??? I'll upload another zip version just to be sure.D.T. Nethery wrote:When I try to import the Fadein-FadeOut.bin it says "Bad or Corrupted Bin File".
Meanwhile, you can set it up yourself very simply. Below is what it looks like:
Under MultipleFX I loaded Fade effect from the Transition group, renamed it FadeOut8 then loaded in Fade effect a second time and renamed it FadeIn8.
Then with FadeIn8 selected, I set a key at 1 to be Transparency 100% and a key at 8 to be Transparency 0.
Finally I unselected FadeIn8 and selected FadeOut8 I set a key at 1 to be Transparency 0% and a key at 8 to be Transparency 100%.
After testing, I saved the effect as FadeIn-FadeOut.bin
- cyrus rebello
Re: Fade in affect?
Hey, thanks for the easy tip, makes life a lot easier and simpler, i'll try it outD.T. Nethery wrote: ↑14 Feb 2017, 15:12Yes. FX Stack > Transition > Fade . It can be any length that you want and you can keyframe the percentage of fade (transparency) over the length of the fade , so yes, it can be customized.cyrus rebello wrote:If there's a fade in and out affect, is it in the FX stack? and on what extent is it customize able?
- cyrus rebello
Re: Fade in affect?
Exact response here, wonder if there's a solutionD.T. Nethery wrote: ↑14 Feb 2017, 16:38Hi, Sven -Svengali wrote:Here's my universal FadeIn-FadeOut.bin file. To use it, simply load it in FX Stack / Multiple FX and check either of the two effects: FadeIn8 or FadeOut8. The default size is 8 frames, but either can be positioned and stretched to any frame count. The Speed Profile curve can be adjusted to weight the rate of fade.
Re: Fade in affect?
I found the problem: I was trying to import Sven's fade preset into the FX Bin for Transition > Fade . But it needs to be imported through the Presets menu . After importing FadeIn-FadeOut.bin to the Presets , it will be in the FX Bin after that.cyrus rebello wrote: ↑17 Feb 2017, 14:23Exact response here, wonder if there's a solutionD.T. Nethery wrote: ↑14 Feb 2017, 16:38Hi, Sven -Svengali wrote:Here's my universal FadeIn-FadeOut.bin file. To use it, simply load it in FX Stack / Multiple FX and check either of the two effects: FadeIn8 or FadeOut8. The default size is 8 frames, but either can be positioned and stretched to any frame count. The Speed Profile curve can be adjusted to weight the rate of fade.
But as Sven posted above, it's easy to make your own Fade presets and add them to your FX Bin. Follow his instructions above.
Re: Fade in affect?
Oops! Sorry about that... I've never posted an FX.bin file before and didn't think about including instructions on how to get it working - my bad. Anyway, hope the FadeIn-FadeOut FX helps.
I keep a separate TVPaint application subfolder called FxBin for all the FX files I create. But it is also very convenient to keep your most used FX in the Preset list, where you can call any one at any time...
- cyrus rebello
Re: Fade in affect?
It's all cool haha, thanks by the way!Svengali wrote: ↑17 Feb 2017, 15:19 Oops! Sorry about that... I've never posted an FX.bin file before and didn't think about including instructions on how to get it working - my bad. Anyway, hope the FadeIn-FadeOut FX helps.![]()
I keep a separate TVPaint application subfolder called FxBin for all the FX files I create. But it is also very convenient to keep your most used FX in the Preset list, where you can call any one at any time...![]()
