I am experiencing a strange issue. Since I bought a new wacom tablet in January the preview will not stop playing immediately when I press stop or any other button. The preview just repeats in a loop and then finally stops after the 5th or 10th loop.
Fortunately it does not happen every time I want to preview something. It happens every 5 previews or so.
I am not sure if the issue is related to the new wacom tablet but it started happening on the same day I started using the new tablet.
I was wondering if anybody has also experienced this?
Re: preview will not stop playing immediately
Something you can already check : Wacom drivers. Are they up to date ?
Yes, everything is up to date.
I confirm your issue, I'm having the same.
To do listed !
(On 64 bit version only BTW)
To do listed !
Good to hear that.
Thank you.
Thank you.
I just wanted to let you know that this problem unfortunately still persists in TVPaint 11.0.8.
I don't have the problem any more and I'm using the last Wacom drivers 6.3.25-2
I also use these drivers (6.3.25-2)
Well... i'm using Sierra and you're still on Mavericks, so that might be the reason ?
We will run a few tests on an old mac.
Edit : I'm using High Sierra now and still no issue...
