lame lemec's drawings!
Re: lame lemec's drawings!
Ok, this is what happens if I get all serious and spend like, 4 hours on a study...
:shock: Wow ! I'm impressed ! Good job !
Mark, it remainds me some Ghibli landscapes (take a look at the book below if you can find it somewhere)
airman
Post by airman »
lemec wrote:Ok, this is what happens if I get all serious and spend like, 4 hours on a study...
beautiful!
great!
lemec
Post by lemec »
Fabrice wrote::shock: Wow ! I'm impressed ! Good job !
Heh, I've been looking through the Spirited Away artbook and seen some real jaw-dropping watercolours. I have the playback for that last one if you want it. Kind of huge, though...
(Win7x64, TVP Pro 11 32-bit)
masterchief
Post by masterchief »
I think that it is very impressive work Mark...
regards,
William
TVPaint Animation Pro v11
masterchief
Geopeto wrote:Thank you for your thoughts on this, your time is appreciated. So far it seems i haven't figured out a decent "system" for working with layers, but my biggest problem is, i just forget to switch layers. I tend to concentrate on what i am putting on the work area and forget all about layers. I do find some very useful versatility, in layers and will continue to experiment.
1. give your layers unique names
2. select the comma keyboard shortcut (,) which is mapped to Layer:Pick Layer by default in TVP v9
3. click on color you want and it will give option to select appropriate layer if it exists on more than one layer
let me know how it works for you....
additionally, use the semi-colon keyboard shortcut (;) which is mapped to Color:Pick to change current color to your mouse click selection
this will work across ALL layers so be careful to make sure you have intended layer active when you apply changes
I have CTRL-Z mapped as hotkey on my Shuttle PRO so I can undo changes...
regards,
William
Spirited Away ... so I was not so far from your source :wink:
The playback ? Oh yes please !! :D :D :D
(try to compress it in QT H264)
Geopeto
Post by Geopeto »
masterchief wrote: 1. give your layers unique names
I will do that, i have not had time as yet, but i will get back to you.
I am guessing from your name, you are were a navy man. I was also, in the early 70's, i would have been working for you though. :P
"When the love of power is overcome by the power of love, the world will know peace.”
The beauty of TVP9 is that this KeyCommand/pointer shows you the thumbs involved so you can pick the one you need without having all your layers labeled with unique names. I love this new little touch!
Sierra Rose
Post by Sierra Rose »
Paul, how do you get it to do that? Once you have the little pointer with the question mark, where do you click? It just disappears when I point it at anything on the timeline.
WinXP 32bit 10.0.17Pro
You point it to a place on the picture -- usually when you are not sure which layer that object sits on.
Sierra K Rose wrote:... It just disappears when I point it at anything on the timeline.
you have to point it in the preview window, not on the timeline .
it's particularily useful when several layers are overlaid, if you want to pick the one underneath,
select it in the thumbnails list (they appear in the order). 8)
Sierra Rose
OK, I got that part to work. I point to the part of the image that is on another layer and the program jumps to that layer. Very nice. But I can't get the popup Paul spoke of where you can see the thumbs. What do you have to do to get that?
oops -- maybe it's just in the beta version. Well, it's coming then, and it's very nice. :oops:
Sierra Rose
Thanks...I'll look for it when it comes out.
Sierra, the popup thumbnails only display when you have overlapping drawings (under the same pixel) on two or more layers - otherwise it simply jumps to the layer with the drawing you click on.
