Export to Harmony
Cardin
Re: Export to Harmony
Post by Cardin »
Sorry, Soom. I did miss that post.
It is possible to have each image flattened with the background color. I can use the tv_ClipsaveStructure command instead of what I'm currently doing but this will require me to do some additional work to make the script work correctly. Probably be a few days or more till I have time to get back to it but it's doable.
TVPaint 12.0.0 Pro
Soom
Post by Soom »
Cardin Collins wrote: 11 Jul 2021, 20:46 Sorry, Soom. I did miss that post.
That would be absolutely fabulous, because then we can have many more options and actual use of the import options! thanks!
Cardin
Post by Cardin »
Soom wrote: 11 Jul 2021, 21:36
Soom,
The attached script should work how you requested. The background color will be whatever is currently selected in TVPaint. Please test it and let me know if there are any issues. Thanks!
TVP Export to Harmony NO TRANSPARENCY.tvpx
(96 KiB) Downloaded 1599 times
TVPaint 12.0.0 Pro
Soom
Post by Soom »
Cardin wrote: 20 Jul 2021, 18:45 Soom,
Thanks so much! I will test it and let you know, however it will have to wait a bit as I am working on another machine for now.
I read some Q & A posts on another forum regarding importing bitmap drawings from the Rough Animator app to Harmony. These same tips would apply to importing drawings from TVPaint to Harmony. I post them here for anyone interested in transferring drawings from TVPaint to Harmony.
QUESTION:
1.) Is it possible to color in Harmony when you do the line art in another application?
I use Rough Animator for line art because I’m more comfortable to draw with that app. And I want to color the drawings in Harmony.
ANSWER:
Yes, using the Rough Animator to Harmony script (available on the Rough Animator website) to import and vectorize your drawings from Rough Animator into Harmony.
QUESTION:
2.) I was able to import my Rough Animator animation in Harmony. But is there a way I could color the drawings without strokes while using the bucket tool or paint tool?
(NOTE: in Harmony it creates a series of closed vector strokes on the Colour Layer which is "under" the Line Art Layer. These strokes are what contain the color fills)
ANSWER:
You can color on the Color Art sub-layer . The ‘Create Colour Art from Line Art’ button in Harmony does not actually care whether the source layer for line art is vector or bitmap, so long as the destination layer for the colours is a vector layer. So yes, you can import line art and then use that ‘Create Colour Art from Line Art’ button to create the colour layer.
Using the Black selection arrow, select your drawings (with 'Apply to All Drawings' selected) and then select 'Create Color Art from Line Art'.
Also try Shift Click on the button ‘Create Colour Art from Line Art’ and select the 'Use rendered version of the drawing' tick-box. It will see the line art within the imported image to use as the source for colour fills (it basically renders the image as a bitmap, and then vectorizes it again, and then applies the colour art function).
Transparent image line art can also generate colour art invisible lines
press Shift+8 or the asterisk key of the numeric keypad.
Refer to this:
Toon Boom Harmony Art Layers - Create Colour Art from Line Art
https://teach.lucassaturn.co.uk/harmony ... _selection
