Well, maybe this is off topic, but the flexibility how to turn on/off auto break instances is very nice. However, I prefer the way it was in TVPaint 10.5. I might be the only one, but when I draw I ALWAYS want to break an instance, especially when I'm on an empty frame. And when using the transform tool I NEVER want to break an instance, because it messes up my layer. So what I did now, is make a keyboard shortcut that automatically sets the layer on auto break instance when using a drawing tool, and turns it off when selecting the transform tool. But this method also has it's flaws. For example: When I want to move multiple layers I have to select the transform tool for again for every layer I want to move, to make sure auto break is turned off...Xavier wrote: ↑16 Feb 2022, 17:38It would help if we could better understand your workflowsChristopherC wrote: ↑08 Feb 2022, 11:46 it's messed with my workflow too, sad to see the old functionality is not being considered as an option.
TVPAINT 11.5.3 NEXT INSTANCE problem
Re: TVPAINT 11.5.3 NEXT INSTANCE problem
TVP Pro 11.7.1
TVP Pro 11.7.1
My habit is similar, I always draw with auto-break. But I dislike that the transform tool doesn't break when I'm in an exposure frame, I always have to click with the eraser first to break, then apply transform.
What I should do is to try and create a script which applies "re-compute" on a layer after FX, merge, or Transform.
slowtiger wrote: ↑18 Feb 2022, 11:27 My habit is similar, I always draw with auto-break. But I dislike that the transform tool doesn't break when I'm in an exposure frame, I always have to click with the eraser first to break, then apply transform.
The problem about "recompute" is that the "repeat images" function wil be lost, right?
And it's has a bit of a delay...
TVP Pro 11.7.1
TVP Pro 11.7.1
Would it be an option to have a checkbox for autobreak exposure attached to tools? (for example: I would like to turn off the auto break always when I use the transform tool, so the autobreak checkbox would be turned off for this tool, and for my brushes it will be turned on)
Could this be a solution? Or will this cause problems elsewhere?...
TVP Pro 11.7.1
TVP Pro 11.7.1
Guys sorry, I'm afraid that if you let your comments here the ideas may be lost. Would you mind putting a post in the "feature & improvement requests" section ?Joost wrote: ↑18 Feb 2022, 11:22 Well, maybe this is off topic, but the flexibility how to turn on/off auto break instances is very nice. However, I prefer the way it was in TVPaint 10.5. I might be the only one, but when I draw I ALWAYS want to break an instance, especially when I'm on an empty frame. And when using the transform tool I NEVER want to break an instance, because it messes up my layer. So what I did now, is make a keyboard shortcut that automatically sets the layer on auto break instance when using a drawing tool, and turns it off when selecting the transform tool. But this method also has it's flaws. For example: When I want to move multiple layers I have to select the transform tool for again for every layer I want to move, to make sure auto break is turned off...
