TVPaint Animation 11.7.3 is available!
ernesttx
Re: TVPaint Animation 11.7.3 is available!
Post by ernesttx »
Interesting. I clicked on Help > About TV Paint and got the screen that shows version 11.7.3 and registration info. If I click on TVPaint Animation > About TVPaint, it still says 11.7.2. So, I'm updated but confused by different versions showing up.
Lukas
Post by Lukas »
Apart from the info not being up to date and most menu items under 'Help' not working, there really shouldn't be 2 'About' menu items. Same goes for preferences/settings. Just have those 2 items only where they're supposed to be and where users will expect them, which in macOS' case is under the 'TVPaint Animation 11' menu. In my opionion ;)
  • Lukas Sketch Panel
  • TVPaint Pro 11.7.3
  • YouTube.com/@ClubBaboo
  • YouTube.com/@FrameOrder
fmhansen
Post by fmhansen »
Yes, I think the "about TVP" is saying 11.7.2, when in fact it is 11.7.3.
Screenshot 2024-03-30 at 9.34.57 AM.png (51.54 KiB) Viewed 7980 times
Hello, thank you for noticing this "About" menu item confusion :)
Regarding the "Help" menu problem: according to our tests, this seems to be happening only on ARM Macs. Also, one of our colleagues on Monterey has it, but 2 others on Sonoma don't!
Lukas' and fmhansen's signatures don't mention Mac models: do you guys have these?
Lukas
Post by Lukas »
I'm on an old 2018 Macbook Pro :)
Actually Jérémy found were the issue came from and is currently working on it :)
Dean wrote: 02 Apr 2024, 10:06 Hello, thank you for noticing this "About" menu item confusion :)
I am on an Intel Mac Mini (2018) and the Help Menu in 11.7.3 does not work
Chillrobski
Post by Chillrobski »
Hello, and thanks for the update! I'm still finding this version like the previous crashes TVPainat after about 15 min of use. I'm on a Mac studio M2 64 Sonoma. Any fix or advice would be greatly appreciated. Thanks again!
Update 1:
1. So I deleted all TVPaint files from my computer, including going through all TVP files in the Macs...Topbar/Go/ Go to/~/Library/ folders. I checked them all.
2. Next, I uninstalled and reinstalled the latest Wacom driver.
3. Just in case I kept version 11.7.1 which was working and downloaded both to my computer's application folder.
4. The Mac now recognizes TVP version 11.7.1 as the default but I can now open the latest version 11.7.3 without crashes.
5. If I delete version 11.7.1 from my application folder the new version will start crashing.
Update 2: Spoke too soon! Crash happened after about 40 min of use... :(
Hironori Takagi
Post by Hironori Takagi »
I installed TVPaint 11.7.3, but even if I select Japanese in the localization menu, it changes to English.
The OS is Windows 11 Pro.
SharaHeart
Post by SharaHeart »
I tried downloading it for my Android device (Samsung S9 Ultra) but it still says it's incompatible....
Any ideas how to fix it?
Hello, my colleague Thierry posted an update regarding this situation on this thread: https://forum.tvpaint.com/viewtopic.php ... 33#p134433
Hironori Takagi wrote: 03 Apr 2024, 04:10 I installed TVPaint 11.7.3, but even if I select Japanese in the localization menu, it changes to English.
Hello, this issue is currently under investigation.
Tsuchida
Post by Tsuchida »
Regarding the issue of Japanese words not being converted when selected, is this still under investigation?
Also, the previous android version also had a problem where the characters with an "X" in the middle of □ were garbled when changed to Japanese.
We are considering using 11.73 for our project,
I am considering using 11.73 for my project and was wondering if you have any ideas on how to solve this problem?
Translated with DeepL.com (free version)
rohandeshchougule
Post by rohandeshchougule »
Hello! The TVPaint is still crashing for me on M1 Mac Pro, it's not as often as 11.7.2 but it still crashed once. Not sure of the cause.
Hironori Takagi
Dean wrote: 03 Apr 2024, 12:57
Another Japanese production company also asked me how to solve this problem.
Is the solution likely to be long-term?
