lame lemec's drawings!
what's that
is it a new plugin?
Can you explain the use and display a screenshot; PLEAZSEEEE?
Mister Lemec
don't forget the mac users please : no .exe...
thanx for your work
thanx for your work
ubik >> doooohhhhhhh....... the game controller thingy works with autohotkey which is windows-only:
http://autohotkey.net/
narf... if only I had a macintosh to develop plugins and other doodads for!
The game controller EXE works with pretty much any USB gamepad or joystick. In my case, I've tested it with a Logitech USB Rumblepad and an MP-8888 SuperJoyBox3 adaptor with a Sony Playstation 2 Dualshock controller.
It should work with pretty much any game controller that will show up in the Windows game controller control panel.
(Win7x64, TVP Pro 11 32-bit)
I think this is a great exercise to do in the morning...
Try to animate a box travelling through space... Try to keep its proportions, and make the box's edges flow parallel to the path of the animation.
Make sure your keys are spot on, otherwise the errors will be magnified in the inbetweens!
It's a LOT harder than it looks!!! This is a very imperfect example...
- funbox5.gif (31.31 KiB) Viewed 42173 times
Man! I'm halfway trapped between programming and animating and drawing fundamentals and developing a style!
Okay...
Okay...
- I haven't drawn a good lookin' girl in a while...
- lois.jpg (31.69 KiB) Viewed 42067 times
- I'm finding it helps a LOT if I sketch out the path that the box has to travel... There's a few other tricks I've learned too, doing this. It seems like such a simple, elementary exercise, but if you're off -- you'll KNOW!
- funbox6.gif (55.61 KiB) Viewed 42067 times
- This is the result of a tool that I've been creating. It's a sort of "magic eraser" that only erases the current colour and leaves the rest behind. I have to recode the brush engine, hopefully to emulate Hervé's wonderful Penbrush...
- keybrush.jpg (10.95 KiB) Viewed 42066 times
The magic eraser has been outdated and replaced with a funky FX-PAINT function!
Basically, when you turn on FX-PAINT, you can use the airbrush, penbrush, mechanical pencil, standard pencil, wetbrush or text tool to paint the FX-stack's effect onto the canvas!
It works by running the FX stack and then storing the result into the Spare buffer, then setting the brush to Merge. You can probably create your own toolbox button to do this, but PPalette goes one step further:
You can turn on a setting to update the Spare snapshot with each brushstroke so that each brushstroke has a cumulative effect. Also planned is a PreFX and PostFX stroke that let you draw regular brushstrokes, and then have the FX stack automatically apply the effect on the stroke before or after the stroke.
- fxbrush.jpg (53.19 KiB) Viewed 41892 times
I'm finally back from Europe (and a month-long stint of cgvfx work)... It looks like this week I'll be roped back into it for a little while, so here's a fairly quick drapery study...
These are some traditional drawings I did on the trip using just a fountain pen (or a pencil)
