preliminarily, what tvpa version do you work on, and what OS are you running ?toonsisters wrote:the CIP button seems to work fine, but the PIP button does not what he is supposed to do.
when I first keep all cut brush options unchecked,
then select a part of an image,
then hit CIP,
then select my target image,
then hit PIP,
nothing appears.
do you have a clue what I am missing?
hmmm... it's not so easy to guess what could be wrong
without more details and/or some screengrabs ...
let try to find the hic :
- after hitting CiP button, verify the brush is really cut, try to draw in your project preview,
just to make sure the custombrush really exists, and is not empty,
- if that's OK, check the 2 .grg files location, make sure they both are placed/copied
in your C:\Program Files\TVPaint Developpement\TVPaint Animation Pro\George\ folder,
to ascertain the script is well reached, right-click on the PiP button, Edit ...
then click on line0 and go to Set Script ... browse in your george folder
and select the PasteOverHeadsOnly.grg file, then "OK", "OK",
- also check if you haven't a Stencil enable, or the Preserve Transparency button enlighted,
- verify if your layer does have frame(s) at your choosen target place,
when you Add an action, or Edit an already existing custom button,toonsisters wrote:...
btw - how do you create custom icons ?
you have in the Edit panel a button named Tool, (in the middle), this [Tool] button
in fact transforms your current custombrush into Icon,
so, here's the way to follow :
- first, draw your button design in a layer,
- cut (Rectangle CutBrush tool) the drawing or part of it,
- then, Edit your custom button, and hit the Tool button, "OK.
