Thank you , Patrice. I finally figured it out . I was doing something stupid, not following the directions !
I think I was confused because for some reason I thought I was supposed to name the file to be saved as .mov file . When I named it Demo_Test.mov then it couldn't save properly . I think I was mixing up the procedure with other screen capture programs that I've used in the past like SnapZ Pro where it saves the screen capture file as .mov .
Demo recorder...
- IceDelight
Re: Demo recorder...
Hi,
I'm sorry, I know this is a really old post. How do I play back the .dip file and convert it to a video format which I can use? Like quicktime .mov?
Thanks for your time.
what happen when you load your anim-demo .dip file as a new project,
then export it as a quicktime video (.mov file) ?
