Photoshop wanabee
Re: Photoshop wanabee
KenC wrote:... TAP TAP TAP why won't this keyboard shortcut work... oh, wrong room :D
till this gets fixed...
did you know that you can give the rooms different color themes?
KenC wrote:One suggestion that would also free up tons of keys; Let us bind more than one thing to the same shortcut and just loop through the tools/functions bound to that key. Say I bound b to brush freehand, brush line and brush filled line. I can then hit m a couple time to get the right tool. This way you could group tools in logical clusters and not have to have unique keybinds for each of them.
Ken,
Pretty sure this could be done using an elementary George script for almost ANY set of options - when assigned to an action-button/short-cut-key you could then cycle through whatever settings you want. I'll see if I can work out a template with a sample and upload it.
KenC
Post by KenC »
@Peter - Good idea, didn't think about the color schemes could be different in the rooms. Might help not to confuse rooms.
@Sven - yeah I tought about that, but the script would need some kind of way to remember states. As far as I can tell there's no way to set a global variable that wouldn't loose scope when the script ends so there's no way to have the script remember the last tool.
There's a function to write a section to the tvpaint ini files I think that could be used for that but I haven't messed around with that yet.
There's no place like ~/
First check the options during reducing: it even hints you which one to choose for reduction.
After reducing, use "Unsharp masking" to sharpen the image to your taste.
Slowtiger, It's a spam ;-)
And if it's not, please Josefina, go to a Photoshop forum, thanks. We cannot support every softwares . (I've deleted the message)
